Does your HOA allow you to work in your garage? Can you keep a car on the street? Can you put an window air conditioner if you wanted?
Yes. No overnight street parking. Every house has central A/C, so need for window A/C. (If you're talking garage, I could run a standalone unit. Plan on buying one for my server rack anyway.)
I'm a "less is more" kind of guy when it comes to the garage. So here's what I'm thinking, for garage ideas. All of this will be put in by the builder. Please, add to the list!
1) 220V 50A outlet for welder / garage heater with light switch
2) A ton of lighting (T8s, I think. Reading through that section of the forum now)
3) NEMA-15P outlets in that nook area
4) Air line from basement to center of roof
5) NEMA-15P in center of roof
6) (optional) Buy side-mounted garage door opener instead of top/center
7) Floor drain for winter slush stuffs
8) Light switch to turn on/off basement compressor
9) Natural gas in garage? Or just use electric for heater?
10) NEMA-15P in attic above garage with light switch (used for shop vac... Maybe?)
And stuff I'll do myself:
1) Finish the garage (Only the walls touching the house are drywalled)
2) High-gloss white wall paint, flat-white roof paint. (Thank you Platonic Solid!)
3) High-gloss white epoxy floor (Although, how well does tile/grout hold up to fluid stains?)
4) Moduline or similar 36"x30" floor cabinets, x3, with a work surface on top
5) Tire storage above work surface, on wall
6) Moduline or similar cabinets next to tire storage, however many I can fit on the wall
Things I need to find a place to store, or get rid of:
1) Floor jack. (Replace with
scissor jack + impact?)
2) Shop vac. (Mount in attic above garage, run hose hole through roof for artificial "central" vacuum system? What about hose storage and emptying filter?
This is cool, too.)
3) Air compressor. (Replace with compressor in the mechanic's room, run a line to the garage)
4) Jack stands. (Top of wall cabinets?)
5) Buckets for car cleaning. (Where can I store these?)
6) Brake bleeder kit (Larger than I'd expected. Maybe room in the fluids cabinet?)
7) Potential future cherry picker/engine stand (Rent? Buy used, sell when done?)
Does anyone know where to get vacuum cleaner hoses with this soft touch stuff on them like
this? All mine look like
this.
edit: Aah, it's called a "hose sock".
