Alchymist
Simple summation - the "duplex" 15 amp receptacle is allowed on a 20 amp circuit. The insides of the receptacle are rated to pass 20 amps thru itself to the next receptacle. The opening for the plug will only take a 15 amp rated plug. To my knowledge, there are no appliances with a 15 amp plug that draw more than 15 amps. If one draws in excess of 15 amps, it comes with a 20 amp plug, and cannot be plugged into a 15 amp receptacle. Can one overload a 15 amp receptacle? Of course, by plugging in TWO appliances either both in the same receptacle, or one into each of two different 15 amp receptacles on the same circuit. In neither case will the outlet be exposed to an overcurrent, as the breaker will trip.
In total: no combination of appliances having 15 amp plugs will cause the outlet to fry, the breaker will pop first. Inversely, the 15 amp plug can be plugged into a 20 amp rated receptacle, but, those same 2 appliances that caused a trip on the 15 amp receptacle will also cause a trip when plugged into the 20 amp receptacle.
