20 Amp Plug With Parallel Blades
Alchymist
Central PA
No, if it had parallel blades, it would fit a 15 amp receptacle. The 5-20 plug has the one blade turned 90° to prevent this.
Bert_
NW Iowa
Does such a thing exist?
Not really sure what your question is? If the 20A plug had parallel blades it would be a 15A plug not a 20A.
A 20A receptacle guarantee's that is is connected to a 20A circuit.
The construction of both plugs is typically the same other than the orientation of the blades.
Cruzan80
Denver, CO
This chart shows you everything you need to know. L5 is 120V, L6 is 240V.
sberry
Brethren, Michigan
And it prevents it from being used on circuits not intended for it, often dedicated for such use. Janitorial is often this way.
I see the woman at the school has a twisted plug, it was installed on a rather modest vac with a 16 cord. Keeps them from using general circuits which are 20A but one never knows whats on them already. They want to make sure she doesn't come along and trip up sensitive equipment, labs, computers etc.
Cruzan80
Denver, CO
LOL, yeah, and there's nothing locking on that chart.
The locking plugs have blades that run arcs around a circle.
Yeah, I was tired when posting. Sorry. At least the chart shows what I meant.
Sent from my Moto G (5) Plus using Tapatalk
Bert_
NW Iowa
Yeah, we have guys off-site taking pliers and twisting the blade so it will go in a 15 amp receptacle.
I did this to my PVC conduit heater...
That way I can use any common extension cord rather than making one with 20A ends.
I usually use a #12 extension cord or #14 but have run it with as small as a #16, that gets a bit warm, I think the heater is 2400W:eyecrazy:
I don't recommend anyone else do this, but it works for me
prostreetamx
Las Vegas
Home Depot carries an adaptor to convert your 20a cap to a 15a end. We use them for Trade shows but they have other uses. The idiot in catering that ordered 750w heat lamp assemblies with 20a plugs didn't have a clue. If we run a standard extension cord to them they would not plug in. Rather than swapping the already added cord caps (not factory molded) they used up 50 of our adaptors which we never got back. We also use them a lot for a fitness show. Most of that equipment has factory installed 20a caps but when used for display at a show do not require the max amps. We do run dedicated circuits to each unit but they will not plug into our #12 cords without an adaptor. All of our distribution equipment has 20a plugs and even our new cord have a combo 15a, 20a factory molded cap.
