rmack898
So I have a 400 amp service to a remote meter base with a panel. I have a 200 amp breaker that feeds the house, and a 200 amp breaker that feeds the shop.
I had an electrical contractor set up the feed to the house.
I pulled 4 conductors to the shop panel. Three 4/0 conductors (2 hots and a neutral) and one 2/0 ground. I connected the conductors to the shop sub panel but I hired the same electrical contractor to make the connection act the meter and check my work.
The electrician made the connections at the meter base and said that my work was fine but I have doubts as to whether it is right.
The ground and the neutral are bonded at the shop sub panel. Since I am running all of the circuits in the shop with EMT, I'm thinking that the ground should be bonded to the metal enclosure and that the neutral and ground conductor in the cabinet should be separated since i'm using the conduit as the ground conductor.
Look at the pics and see if I'm missing something.
