greasemonkey44
I am working on 2007 ford f150 2wd.
I need to replace a wheel bearing/ rotor hub assembly on the Front right corner tomorrow morning. I got a bearing and a rotor with a bearing; and a new nut too.
How should i achieve the 300 ft/lbs the instructions call for?
My highest torque wrench tops out at 250 ft/lbs. I could tighten to 250 and add
a 1/2 turn or 250 and hang my body weight 225lbs @ 1.3'. I could run it on with an impact and call it good.
This is a unique situation. Normally i would buy another torque wrench with the right specs, but the HF only goes to 300 ftlbs.......a 50ft/lb gain for 79.00$.
A good 3/4 is a fortune(300$ plus); and not immediately available
leaning towards the torque then weight; open to any suggestions though!!
