2026 Summer Rust Out - Part Uno
yatg
Southern Oregon
What works best for rust removal?
lets find out
Test items are 4" pieces of old rusty 1/2" black pipe
item 0 control - no rust removal
item 1 plain water
item 2 vinegar (5%)
item 3 evaporust
the evaporust is slightly used.
ran out of new and not going to buy more just for this.
item 4 c.l.r.
item 5 citric acid
1 pint water, 1/4 cup citric acid powder
item 6 citric acid with baking soda
1/8 cup (2 tbs) baking soda
item 7 citric acid with washing soda
1/8 cup (2 tbs) washing soda
item 8 citric acid with washing soda (old)
this solution made up a couple weeks ago and used to clean up a bunch of stuff - that's why its black
this is to test the longer term efficacy of the solution
Methodology
Soak each item in a solution for 24 hours
rinse and brass wire brush the item
evaluate results
soak for another 24 hours
rinse and brass wire brush and soap pad the item
evaluate results
Day 1 - Monday
All items were
Stamped with a item number
Rinsed in plain water,
Immersed in 1 pint of the solution (except for control item)
hung from wire to keep them off the bottom
These pictures are from Monday just before noon, when the items were first put into the respective solution.
left to right, item 0 in nothing, item 1 in water, item 2 in vinegar
item 3 in evaporust, item 4 in c.l.r, item 5 in citric acid
item 6 in citric acid + baking soda, item 7 in citric acid + washing soda, item 8 in old citric acid + washing soda
Now we wait ...
Y
yatg
Southern Oregon
Day 2 - Tuesday
Observations after about 24 hours
(click on thumbnails to see larger image of items in containers)
item 0 - control
no change
item 1 - water
some rust loss into water
item 2 - vinegar,
some bubble action, some debris bits in bottom
item 3 - evaporust,
turned darker, sample turned gray
item 4 - c.l.r.,
turned from bright green to yellow green, some debris bits in bottom
item 5 - citric acid,
lots of debris bits in bottom
item 6 - citric acid + baking soda,
some debris
item 7 - citric acid + washing soda,
less debris than plain citric acid, more debris than baking soda
item 8 - old citric acid + washing soda
too dark to tell
Visually, it looks like the evaporust did something, but the rust remains on most of the items.
Items were rinsed in water and a brass brush was used to remove any residual dissolved substance sticking to the item.
Items 0 to 8, left to right.
All the chemical variations had significant rust removal. That was unexpected looking at them before rinsing. Most of the surface rust that was visible in the above container pictures was brushed and rinsed off.
Items 0 ro 4, left to right
Item 0 (control), no change
Item 1 (water), no change
Item 2 (5% vinegar), worked surprisingly well.
Item 3 (evaporust), worked as expected.
Item 4 (c..l.r.), not so great
Item 5 to 8, left to right
Item 5 (citric acid)
Item 6 (citric acid + baking soda)
Item 7 (citric acid + washing soda)
Item 8 (old citric acid + washing soda)
looking at this grouping,
#5 the citric acid worked well,
#6 + baking soda worked not as well
#7 + washing soda, worked well
#8 the old + washing soda solution appears to have worked the best.
That makes no sense. The solution should have been weaker having been previously used for a lot of derusting.
It could be more concentrated due to evaporation.
If could be an ongoing chemical reaction over the last couple of weeks that makes the solution more effective.
It could be that item #8 wasn't as rusty/rough as the others.
Items were returned to their soaking containers and will be evaluated again tomorrow.
Y
yatg
Southern Oregon
Day 3 - Wednesday
The results after another 24 hours in the solutions.
I'll spare you pictures of everything in solution, most looked about the same but there were some things of interest.
Item 3 - Evaporust
After two days the solution went from clear to black.
Item 4 - C.L.R.
Some interesting mottling
Items 5,6,7 - Citric acid mixes
Mostly still clear
Used a brass wire brush under running water to scrub off the remnants
Finished up with a steel wool soap pad scrub.
Lined up, there are visible differences.
Items 2 Vinegar 5%, 3 Evaporust and 4 C.L.R
The Evaporust did a better job
Items 3, 5, 6, 7, 8; Evaporust and the citric acid solutions.
The Evaporust (left) is equivalent to the fresh citric acid solutions, and the results from all these solutions are pretty much the same
But again, the older citric acid + washing soda solution (far right) did the best job.
There's hardly any rust in the pores of the metal.
Y
yatg
Southern Oregon
Day 4 - Thursday
Conclusions
Most of the commonly used rust solutions work to some degree, and as expected some will work better than others.
Vinegar, at least the 5%, isn't a good option.
C.L.R. isn't a good option. Its almost as expensive as Evaporust and doesn't do as good a job.
Evaporust works, but we know that.
The citric acid mixes need further testing, in different concentrations and with/without baking/washing soda.
The outlier is the old citric acid+washing soda mix.
Even if you consider there were some variations in the rusted samples, it did a noticeably better job.
knucklehead 61
i need to de rust some heavy chain for a project & your testing is very helpful.
thank you for sharing.
