cookiemonster
- Joined
- Feb 1, 2013
- Messages
- 187
Just wondering when you guys use 20mm sockets and up to the 30s for?
I kind of think I'm this board's lone bike mechanic, but I use 24, 26, 28, and even 36 mm sockets frequently on topcaps and overhauling dampers on mountain bike suspension forks.
What's the torque like for those nuts.? Can they be removed with a 10 or 12" adjustable ?
Usually no more than a few tens of inch pounds tops. There is some resistance on removing the top caps sometimes due to dirt and o-ring resistance.
On the note of using an adjustable. It can be done (I have on many occasion) if the caps are not to snug and the crown does not restrict tool space. The big problem is that the components are generally built to be as light as possible and made from aluminum resulting in delicate parts. Many times the profiles on the caps are so low that the sockets may need to be ground down to remove the radius on the open end.
I think I've seen this mentioned by someone in these forums before but I've come across a 23mm hex banjo bolt for oil cooler lines on a old 80's vintage Mazda RX-7 rotary engine.
Thats a odd one I dont think I have ever used my 20mm or 23mm
