Hey all, I'm planning a 20 x 22 detached garage build at my central Florida home and have a few questions I'd like to get your thoughts on. The garage will have a golf simulator in it and mostly used as a man cave and to tinker on woodworking and car projects.
First off, what type of framing would you recommend?
To make space for the golf simulator, I want the walls at least 9' tall. Like most Florida houses, my home has CMU walls on a slab-on-grade foundation. Is this the best way to go for a garage as well? I'm also considering stick framed walls on a short stem wall. I'm planning on having 2 windows, one access door, and one 7x16 insulated overhead door. Since I'll be using it for a golf simulator, noise control and climate control are important.
Beyond the construction methods, anything else you would recommend for a new build? For example, I don't really need plumbing, but should I have this roughed in for potential future use? My main goal is to avoid finishing the build and think "Oh, I wish I did this or that from the start." Thanks in advance.
-Kevin
-Kevin
