Hi,
Been lurking for a while, I'm finally ready to build my garage
I'm in Canada and English is not my first language, so bear with me.
Brand new house, most of the landscaping is done. It's garage time. I made most of the landscaping myself and the driveway ends up like this:
About 18" of compacted crushed rocks surrounded by a "landscaping" block wall. This is where the garage will sit. Plumbing is done as you can see. I have been doing some reading on the forum (after doing all this, duh) and I have some questions before setting up the forms and pouring. Keep in mind that this will be a radiant heated slab and I will install 2" foam underneath the slab.
1. Most of the slabs I saw here have a thicker edge. Much like this :
My understanding is that it reinforce the slab where the walls are but I'm not sure. As you can see, I did not plan for this in my preparation. Would a ~7" concrete slab require this? Is it possible to simply lay the insulation level and pour?
2. I plan on a 1" slope/drop from perimeter to center. Is it enough? Drains are legal up here.
3. I'm on the fence when it comes to mesh vs. rebar. What's your opinion on this? Rebar sounds like the way to go but much more work for a novice.
Thank you!
I'm in Canada and English is not my first language, so bear with me. Brand new house, most of the landscaping is done. It's garage time. I made most of the landscaping myself and the driveway ends up like this:
Thank you!
