Mike in Ohio
Good friend asked me to help trouble shoot a wiring problem in his basement. He was convinced I helped him wire it (which means I wired it with his help) back about 1995. I remember helping frame it and hang but not finish the drywall. After about 10 minutes it was very clear to me that I had nothing to do with the wiring, I stay very much in my comfort zone with electricity. I have no clue what some of this was, including using a 30 amp 2 pole (220) breaker to power 2 circuits, I hope that makes sense to you experts. The actual problem is both circuits controlled 3 way switches, one controls the overhead lights and branches before the switch to power the bottom half of the receptacles. The second 3 way switch powers the top half of the receptacles so floor lamps can be controlled by the wall switch. Friend in question decided to replace switches and receptacles with a different color. when he was done the top (switched) receptacles didn't work. As I got into the mess it seemed that parts of both circuits shared a neutral, something I never would have considered 30 years ago, or even yesterday. At one point I shorted one of the circuits, it did not blow the breaker, but there was no power to that circuit after that.
Question is: is it possible that the breaker didn't trip because only one side was shorted, and the other side wasn't, but something melted inside the shorted 1/2 of the breaker causing the loss of power to that circuit but not the other.
The end result was I created a new circuit for the stuff that didn't work with its own neutral and ground, but the 220 breaker still bothers me, and I think I need to replace it with 2 15 amp 110 breakers, this is a bedroom.
If all this made sense, what do you all think??
