220 circuit switch
brownbagg
how do you wire a switch for a 220 circuit, no not talking about a shut off or circuit breaker but a motor control for a motor that runs off of 220. it not a replacement motor but something Im making up that using a 220 motor.
so I have tow hots and a ground. The motor only pulling 3 amps, so nothing major. Do i use a double pole switch or some high dollar unit only from the supply house.
I have replace 220 motors and ran 220 circuits but never had to add a switch to a circuit, and no I dont need a circuit cut off switch, we are talking motor control.
kwb
PNW
I did what you are asking once with a double pole switch and it worked fine
6PTsocket
Everybody correctly recommended a 2 pole switch. Don't forget to Use a 3 prong plug that carries that motor ground to the house ground in addition to the 2 hots.
Norcal
A 2 pole switch is the preferred method but is not required by the NEC unless it is a disconnecting means.
mm08822
Does your motor have internal overload protection?
If it has internal o/l protection, then just a manually operated Horsepower rated switch can be used.
If it does not have internal o/l protection, then you need a manual starter (with o/l protection) or you could use a starter - which is a contactor in series with o/l protection relay to drop out the coil of the contactor if o/l occurs.
And of course as already stated, grounding of the motor/frame is required.
Another consideration is - do you need 3 wire control? 3 wire control prevents automatic motor restart upon recovering from low voltage conditions or loss of power entirely. A manual switch does not have those features. Motor application and safety usually determine that need.
