You have to watch the HP ratings. A 50 amp Leviton recep only has a 3 HP rating. So for most members on here with larger compressors this isn't even an option.
Specs taken from here:
http://www.leviton.com/OA_HTML/ProductDetail.jsp?partnumber=5374§ion=42418&minisite=10251
I've always been puzzles/amazed at the electrical equipment mfg./NEMA ratings. Following this, my 3 HP 220v motor which draws 14 -15 amps (nameplate rating) should be wired with #6 wire on a 50 amp plug and attached to the factory #12 wire from the motor. Why not use #12 wire, connected to #12 wire on a 30 amp plug with a 30 amp breaker? Or let's just start puttiing the correct amp rating on the devices.
