220 garage wiring
DFW-LSX
Houston, TX
Sry if this is a repost I searched and didnt find anything that really answered the question.
Im 24 and the wife and I got a house built last July. I wanting to get into welding but the house isnt equipped for it. Im looking at hiring a contractor for it just was kind of hoping for a heads up one what type of cost this would be. I know it will vary contractor to contractor just looking for a ballpark. Also I have just a standard bulb in the middle of the garage (unacceptable!) so from reading on here I gather T8? lights are what I want. Will I need to upgrade the wiring for these? Im not looking for a shortcut, I want it done 100% correct. Shortcuts always cost you in the end, I would rather pay the money once. Thanks guys I enjoy learning from you all daily.
p_mori7
Montreal, QC., Canada
I ran 240V to my garage myself in a trench, total distance about 75'. The cost of the cable was the biggest expense at right about $500.00 (3/3 Aluminium direct burial).
If I include the rental of the ditch witch, the panel, the conduit up the side of the house & garage, breakers, Hammer drill & coring bit rental, it's right up around $900.00
You can probably do much of it yourself (ditching, backfilling, drilling, buying materials, etc), and leave the hookup to an electrician to save a bit on his labor cost.
eljefino
Is this an attached or detached garage?
Before I built my garage I welded with my kitchen stove outlet and a homemade 50' extension cord.
Tell the wife your welder outlet doubles as an "electric car charging station" and your house will be greener. :D
pattenp
Virginia - USA
With assuming the garage is attached there are still too many unknowns to give you a good answer. If the one light is on a circuit with other lights then you may need a new circuit for the T8's. You may need a sub-panel in the garage or if you have the space in the main-panel you may be able to come from it with some new circuits to the garage. Depending on how it needs to be done the price can go from a few hundred dollars to over a thousand or more.
Falcon67
Merkel, TX
We can't ball park it from here but if you are in Fort Worth it's likely you can't get a permit to run your own feed to the garage. Grew up there and even in the 80s the inspectors were pretty hard ***. You will just have to make some calls if you don't have the expertise to fly under the radar. You could probably do some of the dirt work to save $.
As for the T8s, you can hang plenty off one 15A circuit. Figure 1A or less per 4' two bulb fixture, so 8-10 lights is no big deal as far as load goes.
D
DFW-LSX
Houston, TX
K awesome thats about what I was looking for. Yeah the garage is just a 20x20 attached. Thanks a lot.
Yeah FTW is crazy strict, im going to start getting some quotes as soon as Im home from Afghanistan. Thanks!
Aceman
Eastern Oregon
I'll mention a few things that'll affect the price:
Is there a panel in the garage close by? Does it have any more spaces?
Are the walls finished or open studs? Will the wiring be concealed or in exposed conduit?
D
DFW-LSX
Houston, TX
Yes the panel is nearby and the walls are finished. I dont mind if its exposed.
