dwall174
I have an old Marquette arc welder with a 3 prong 50 amp cord that needs to be replaced! The current wiring has the two hot leads connected to the switch & the ground wire connected to the main transformer's frame.
The welder has fiberglass side panels with a top cover & bottom frame made out of metal. The top cover & bottom frame are constructed so that the fiberglass isolates them from the inner transformer's frame.
My garage is wired with a 4 wire feed so I would like to replace the cord with a 4 prong plug which will give me a neutral wire that I can use to power a small 120 volt cooling fan.
Being that the fiberglass side panels isolate the top cover & bottom frame, Am I correct in figuring that the neutral wire will go to the transformer's frame & the ground wire will be connected to the metal top & bottom?
Thanks Doug
Thanks Doug
