220 plug
daddycreswell
Middle Tennessee
I think I need a 220 outlet in my garage, I should have done it in the beginning but I didn't. So what is the average cost to put in a 220 outlet? I am not going to do it myself.
Panel in garage, location of plug will be a foot or two away from panel
readhead
Durango, Co.
Could be twenty bucks or 200 bucks. Where is the panel? is it accesable? Is there room in the panel? How far do you need to go?
Lots of variables. If you can't do it yourself then call a couple of electricians and get quotes.
chris142
apple valley,ca
I had a guy come out. Ran 60ft of tube to my garage from the box to garage then another 30 ft to the outlet in the back of the garage.
Total cost was $1500.
Would have been 2x that for any other guys plus permits
D
daddycreswell
Middle Tennessee
Talked to my neighbor he does it on the side, said he would do it for the cost of parts, which he said would be about 25.00
Sent from my dumb apple products my work makes me use.
bmxdad
Puyallup, WA
Curious ... so a couple of questions:
Is this an attached garage?
Is the panel in the garage?
Is the panel recessed into a wall?
Do you want to have the 240v outlet next to the panel?
D
daddycreswell
Middle Tennessee
Detached, yes panel in garage, yes recessed and plug close to panel is fine
Sent from my dumb apple products my work makes me use. @bmxdad
bmxdad
Puyallup, WA
How many wires to the garage panel from the main panel?
What is the amperage to the garage in the main panel?
Pictures are worth a thousand word :)
D
daddycreswell
Middle Tennessee
Don't have a picture on hand, neighbor said it will be fine. There is a slot left for a 220 plug, there is already a 220 breaker installed
bmxdad
Puyallup, WA
What amperage are you looking for in the new garage outlet?
Sorry for all the questions ... just curious :)
Norcal
A common "220" size where 220V is still used is 16 ampere. :evil: Sorry could not resist.
But the question above is valid as the cost is going to vary widely from 15 ampere to 100 ampere $$$$, and the brand of panel could come into play if the panel was obsolete. Want try to find SQ D Trillant breakers?
Cutler-Hammer/ SQ D XO, obsolete since about 1960 & 50 ampere is the largest size.
Zinsco/Sylvania.
FPE.
I-T-E Pushmatic.
Wadsworth.
There is a lot of things that need to be known..........
c4cruiser
Lacey WA
That's a very good question! What equipment do you have that requires this outlet and what amperage? 30A? 50A? or??
kelpaso1
MEMBER EMERITUS
New Brunswick
How far from the panel?........does not anyone read the posts?
I agree. He clearly said in his first post and a few others after. But seems like no one knows how to read before they reply, asking is the panel in the garage and how far from the panel to the plug:willy_nil
Edit: I see he edited his original post and maybe that info wasn't posted at first.
D
daddycreswell
Middle Tennessee
No problem on the questions, 30 amps is the max draw. I am making reproduction radio control car body's from lexan. I am making a heat box to warm the lexan and I am planning to use a oven element with a plug on it to make the hot box and warm the lexan. The element is 3000watts and 30 amps.
D
daddycreswell
Middle Tennessee
Of the subject of the thread, but since you mentioned it...... what bodies are you reproducing?
Right now the only one I have is the traxxas ford raptor. I made a plug from plaster of pairs of it. Just trying to get everything right to do it. Then I am going to buy a few new bodies and mold them. I should be able to make a body for 4.00 each. So my boys can bash all they want to, have a couple of friends I will sell to for a few dollars.
bmxdad
Puyallup, WA
Cool body, where did you get the dimensions?
On the garage .... what size is the main breaker in the garage panel?
D
daddycreswell
Middle Tennessee
I took my current body and filled it with plaster and pulled it from there.
The main breaker in garage says 60 on it. Sorry really don't know much about it.
bmxdad
Puyallup, WA
Ah, I thought you were carving your own bodies. Would be easy to mod one though ...
60 amp should be fine, as long as your not running a big compressor or other heavy load. How are you vacuuming the lexan down?
D
daddycreswell
Middle Tennessee
I'm starting with a 6.25 hp shop vac, might have to build a true vacuum system.
D
daddycreswell
Middle Tennessee
