220 Routing issue
77irish77
I recently moved into a new home and would like to add a 220 line to my attached garage. The main breaker is on the outside of the garage wall just opposite of where I would like to locate the oulet inside. The run would be very short, basically the width of the wall.
I had an electrician come out and he suggested just drilling through the back of the box. Is this ok? What would be involved in the way of conduit etc?
MrMark
Southern Cal.
Is this outside panel (combination meter main/loadcenter?) surface mounted on the outside or semiflush in the wall?
ezzzzzzz
A picture is worth a thousands words. What is the 'breaker' for? Is it actually a 'disconnect' for a sub panel in the garage? Whether you can just extend from the 'breaker' to an outlet a few inches away is very questionable. The outlet you desire must be protected by an overload device for your protection.
MrMark
Southern Cal.
Is this a loadcenter? How do the wires get inside the house? 90 degree conduit fitting through the wall? A big KO and ****** through the back into the wall cavity? If so that is how you would get the new wire inside for the compressor.
77irish77
MrMark, I just went out and checked. Feel like an idiot, the conduit going into the garage was obstructed by a wire bundle. Thanks for the input.....false alarm.
