Ricky Joe
Thanks!
I just recently purchased a drill press and bench grinder. I think I may also have bought an education. Apparently these items were imported into the US from Australia, and operate on 220volts, 50 hertz. What are the ramifications of operating these at 220v, 60hertz, or should I just replace the motors? Also, does Canada operate at 50 or 60 hertz?
Thanks!
It will run faster than the rpm's stamped on the nameplate. Which means it will run in accordance to 60 hertz motors, ie., 1725 or 3450 rpm in most cases.
The voltage is nominal 220 and running at 240v should make no difference.
It should theoretically run cooler, as 50 hertz motors have less cooling from fan rpm's if so cooled, or made with more iron to act as a heat sink if not fan cooled.
What horsepowers ?
Nominal voltage in the US is 120v/240v NOT 110v/220v. 220v hasnt been used in the US for decades!
Nominal versus actual. Nominal refers to that which is used in common parlance. Like a 2 by 4 isn't actually 2 by 4.
Actual voltage can be as high as 125/250 often times during summer months.
Ok sounds great but it's not running 240 with 2 hots, it's running 240 with 1 hot 1 neutral I believe. Right? Or is that irrelevant?
Lol no. A nominal 2x4 is 2"x4". It's dimensional lumber which is not 2"x4".
Also if the tool is rated at 220 volts, possible in europe, hooking it to 240 volts here would be providing it with too much voltage, could let the smoke out. Imo.
To prove that hook something up rated for 240 to a circuit of 277 volts.
We used to run 240 volt welders off of 277 all the time,not a big deal.![]()
Could it potentially affect rotation?
