FYI: Look at what your saw's motor is rated at then buy an in-line over current protection device (power strip with built in fuse/breaker). I don't know where you are and I'm not an electrician so me spewing rules/code will just embarrass me when I say something not accurate...
That said, you aren't supposed to plug a 15A device (6-15p) into a 30A circuit/receptacle (6-30r). Because that circuit's over-current protection is set to trip on a 30A basis, not 15A. Breakers trip at (as I understand it) roughly anything greater than 85% constant load or up to 125% on spikes. You could easily fry a 15A rated device by swapping out the plug/cord and plugging it into a 30A circuit.
They sell (I think they are called "in-line") over-current devices. It's a contraption that's like a breaker/fuse that allows you to safely step down from something like a dryer outlet to a lower rated device. My HD has them on the shelf in the electrical isle. It looks like an adapter. There's a couple different kinds. Just pick what you want to plug it into (know your dryer outlet NEMA numbers) and know what you want to plug into it (know your TS nema plug numbers). Easy... Then from there you can run an extension cord appropriate for the TS.
I've got an old 10" Delta Homecraft tilting table (yes tilting table, not tilting arbor) TS. Grizzly is a good name... I'm a little jealous!!
edit: for the 220, assuming it's a 20A motor/saw, just buy the over current contraption and a decent 125A (5-15) extension cord then clip the ends and put 6-20p/r on the ends.
