I'm running this Sunday I am confused please advise. The spec sheet says the stripped wire is the nuetral it a 4 gauge that means that the 3 wires left would be hot hot ground. Why would the isolated ground be bigger than the nuetral.
If the wire is being terminated outside tape the stripe wire ends as green for the ground and one of the blacks ends white for the neutral.
It's a cable so yes it is (All sizes of cable are able to be reidentified).is that kosher anymore?
Not quite. #6 and smaller cannot be reidentified as a grounded (white or gray) or grounding (green) conductor...It's a cable so yes it is (All sizes of cable are able to be reidentified).
One of you is correct.....Not quite. #6 and smaller cannot be reidentified as a grounded (white or gray) or grounding (green) conductor...
