460Rustang
New member from vintage-mustang.com,....Israel, if anyone hangs out there also.
Existing garage is wired only for 115, recently picked up a 230 compressor and a 230 Lincoln MIG,...now I need some juice.
The existing main svc panel has only the service connections inside leading to the breaker panel inside the house, 200 amp.
I wanna jump from this exterior main svc panel to a closely mounted sub panel, then 125 ft underground to the garage. There's no way to get from the interior breaker panel to the garage. It's a story and a half Acadian with no visible, straight path.
Both the welder and compressor pull 20 amp each. Being a one man hobbist garage, I can't envision needing to run more than 20 amps at a time, there's plenty 115 for all other supply.
But, with that being said, I would like to have two garage outlets, so as not to have to swap back and forth with a single plug.
I've been getting very mixed and conflicting advice on what to run.
I was thinking about 125 ft of # 8 THWN through conduit, from a 30 amp breaker in the sub panel into one garage receptacle then jumping to the next from that one.
Please gimme some input.
Also as a related question, what are some of your tool "must haves", that might make me wanna rethink my 30 amp max requirement?
Currently building a 67 BB Rustang from the ground up, so all tools will be car hobbist related, one at a time having only two hands.
THANKS!!
THANKS!!
