230v air compressor recommendation needed
mroneeyedboh
So at first I was after a 110v compressor. Then after reading online I see that you dont need a neutral for 230v, and you can use the white wire as a hot thus now making that circuit 230v.
With that said, I need some recommendations on what I can buy. Id prefer a big box store so I can pick it up. Its going to be used for impact, air ratchet, MAYBE a cut off or air hammer. Possibly a small HVLP or similar paint gun, oh and tires.
It wont be used a lot, just when I need to work on something.
With that said what do you gusy recommend? I checked CL and I havent seen anything in the past 1-2 months, just a few big boys that I dont need.
Thanks!
lemons12
South TN
HF is rebranded.
There are only a few different mfgs.. You can see that when you look at the specs.
HD is probably the cheaper I think for a nice 80? gal... Powerful. And they take competitor coupons.
md21722
Mt Juliet, TN
Air hammer uses the least air of any of the tools listed and cutoff uses the most. With a 60 gallon big box store unit you are buying a basically disposable unit that will run everything but the cutoff for normal use. I don't recommend them because they are typically very cheap Chinese made junk. But they will work. 3.2HP requires #10 Romex or #12 THHN (in conduit) by code. 2HP is the largest you can run on #12 Romex by code.
firebox40dash5
My 120V, 20gal Speedaire/CH does fine by me and was $350ish delivered from Zoro. The motor is a Marathon hecho en Mexico, and supposedly the pump is US-assembled. Never been a CH fan, but so far I can't complain. I don't use it a ton, I'm not doing side jobs, but it's run my 2135, air hammer, and even the whiz wheel. I can't say I've ever had to wait on it... not saying it'll move mountains, just food for thought.
Just to clarify, you understand unless you have 3 conductor (+ ground) wire, using the white as the 2nd hot makes the whole circuit 230v... so hopefully you have a circuit with one outlet (or you can abandon the rest), room to switch in a double-pole CB, and enough wire length to get to said double-pole slot.
M
mroneeyedboh
Thanks guys I do have a dedicated circuit for the Ac. Just never bought one.
I did run yellow 12ga Romex. The run is a out 30' long
by921
It just bought the 60 gallon from lowes and I am
Very impressed. It runs my die grinder non stop for 10 minutes and can go longer. Also run a da sander and it does just as well. I was looking a 1000$ compressor but could not buy one due to my fairly infrequent use. For 500$ seems like a good deal.
CNGsaves
KS and OK
Not sure I'm convinced you REALLY know what electrical needs you should have for 240v air compressor. You do know that it needs a DEDICATED 240v electrical circuit with appropriate HARD-WIRED connection based on HP of the motor powering the compressor ??
Do NOT wire the run before you decide on a compressor. 12 gauge wire likely will NOT be adequate.
GJ Sparky's will give you detailed answers on what wire is needed . . .
. . . . . AFTER . . . you decide on what 240v air compressor to get.
md21722
Mt Juliet, TN
The OP already ran #12 Romex which means by code the OP cannot run anything more than a 2 HP compressor. Lots of people do run 3.2-3.7 HP off #12 Romex, but it doesn't meet code.
