JCook5003
Hey Guys-
The day is finally here, I've started construction of my new shop. I'm tearing down an 80 year old 20' x 80' pole shed and rebuild back a 24' x 50' x 12' sidewall building. It will contain a 24' x 30' shop and 24' x 20' farm equipment storage area.
Here are some light plans I quickly drew up today of the building.
Foundation:
I've built several pole barns for people and never have been a fan of placing wood in the ground. I use perma-columns on a prior build and without equipment found them hard to set with just two guys. I've decided this time around to monolith pour the floor and 2' x 2' x 2' footings under each post and use dry set brackets anchored to the floor. I will then be using steel trusses on 10' post centers with vertical 2x6 purlins. This photo should clear it up.
Here is the existing building that will be torn down. Having a friend bring his backhoe down to help with this process.
I'm confident in my ability to build a strong building, but I've never insulated a pole building before. I'm still trying to decide the best way to insulate the roof to prevent "rain". I'm thinking of using that bubble radiant barrier over the purlins, then install the metal over that. I'm also considering house wrapping the entire shop before I install the wall purlins. Then insulate the walls later down the road. Opinions? Thoughts?
Should be fun guys, stick around and watch me work really hard in the dog days of summer. Thanks for checking it out.
Foundation:
