Holy cow! Sorry, too many questions. Over the word limit.
holy cow is right. holy wall of text on your part. is your return key broken on your typewritter?
I hope they require a neutral everywhere.
Please do explain why, especially where it will never be needed. do you own stock in southwire?
NEC is going there eventually.
Please provide a bonafide reference for this. and just an FYI- i know several electricians who sit on several of the CMPs so any ******** you post here can be verified and snuffed out. but please do post it. but wait til i refill my bucket of buttered
On HVAC, we run into circuits where they use the ground as a neutral everyday and I can't stand it.
A dummy running neutral current on an EGC hardly quantifies the need to run neutrals everywhere. why not just fix the issue the pizza pete created?
At any time someone will throw a transformer or something that needs low voltage and use the ground.
Use the ground for what? neutral for a 120v primary? so why did someone run 1 ungrounded conductor and 1 ground instead of a neutral? sounds like you have some really bad handyman out your way.
When an A/C compressor is said to have suffered a lightening bolt induced damage, it is never the lightning, it is the grounding system that could not attenuate the surge and the copper line to the furnace brought the current inside.
sounds like your grounding system is not up to snuff. I used to work on grounding systems for microwave towers. we have had towers take direct hits from lightning and not a single piece of equipment was damaged. why? because the grounding system was installed properly and did its job.
but what in the hell does this have to do with your bogus rantings about requiring neutrals everywhere? ADD much?
BTW lightening is something entirely different...
Plumbing for grounds is crazy to keep doing. Ground rods are secondary.
so now you want to remove bonding on plumbing or not bond plumbing lines? yeah no. do you even know why plumbing is bonded?
ground rods are secondary to what? can you speak in complete sentences?
"We" would be myself, my recently deceased father and our employees. The company was in his name. If you lived in our 3 surrounding counties and had 3 phase equipment, you probably called us. I knew of no other person who even took the Journeyman electrical exam but me in the area.
so you ran neutrals to 3 phase equipment just because you might need a neutral in the future? smh
are you sure you didnt take this exam out of someone's trunk in an alley somewhere?
what are are you in?
I would have found him for sure and possibly hired him. I have some formal training and was the only one that I had ever seen with a code book.
I find that really hard to believe. many things you have said here go against proper training in this field and established code. was this code book called 'thumb rules for backwoods electricians' 10th edition by chance?
When I post things, I will always try to give general advice because the people who would listen to such advice are not understanding something somewhere.
the "advice" you have given is awful. youve been called out by multiple electricians. when will you quit? and you are the one who has a poor understanding here
Forums are for general advice, generally.
not even sure what that means. sounds like word salad.
I seek detailed information but find many old forums where all the topics were discussed to death.
why do you seek detailed information when you supposedly have the formal training and a code book? arent you the one thats supposed to be giving out the info?
They are not useful resources after a while to most people, yet the ones who wrote it ten years ago wrote it as an end all publication.
well your resources definitely arent useful. i think most of us here will agree on that.
For instance: codes change. People's adoptance changes. I research motor oils often and if you read a post that is ten years old, you might be using that is completely opposite of current reality. Think turbocharger coking. When a topic is brought up again, it is not because the new reader or poster doesn't believe or agree with what was said previously.
what in the world does that have to do with the price of tea in china?
They likely don't have the time to spend 3 weeks of their life reading personal conversations, arguments, rants, fights, jokes and a whole bunch more. I am disabled. The reason, I don't charge for my time to do anything at all is because I have a huge memory defect where I can't transcribe information.
This might explain the responses you are posting here... im sorry for your disability. perhaps you should just sit back and be a reader only. let someone else teach you...
If I could, I would be zipping through the NEC to very accurately state things with actual references. Originally, I came on her to get info about vehicle lifts and vertical lift garage doors. I found some valuable information, but noticed a very large inactive following with a lot of stale posts. New threads, posts etc... keep them coming so our conversations stay relevant. Have fun out there.
huh? theres tons of new posts every week. not sure what in the world youre referring to
