Another 240 question here. Please help me understand the difference between the neutral and ground when only using a 3 prong/wire cord. For example, my welder and compressor only have 3 wire hookup. Do you use the neutral, or ground? My sub panel has separate neutral and ground. I know either one will make them work, but what is the correct way?
At a previous house, I got quite a shock from a neutral wire on a light circuit, that still baffles me.
I know that neutral and ground go to the same place, but are separated. Does 240v carry a load back to the panel via ground? Or only 120v?
So on my 240v compressor that has 2 hots and a ground, why don't I get a "neutral shock" if I touch it, or the metal conduit while the motor is running, yet I got zapped from a neutral on a 120v light circuit?
Thanks for clearing this up.
Just how does a neutral provide equipment protection?
if u disconnect it, grab it with one hand and touch a grounded panel with the other hand!
