atthebeach
I'm planning a small shop expansion which includes finally bringing 240 volt power into my shop. Every slot in the main breaker panel is full, but my electrician has proposed doubling up some of the 120 volt circuits with tandem breakers to make room for a 50 amp breaker that will feed a NEMA 6-50 outlet.
The welder I have in mind comes with a 6-50 plug, it is internally protected, and the manufacturer recommends a minimum 40 amp circuit. However, other equipment I am considering needs to be protected with a 30 amp breaker and some with a 20 amp breaker. Now, I can only use one piece of equipment at a time; so rather than running three new circuits, I am thinking about setting up a spider box with 30 amp and 20 amp breakers that when needed could be plugged into the 50 amp outlet. This is a temporary approach commonly used on construction sites, simple, and I believe safe, but probably not specified in the code. If I ever sold the house, I would simply unscrew the spider box from the wall and take it with me to avoid any code issues.
An alternative and more permanent approach would be to have the electrician install a double throw safety switch which can either feed the NEMA 6-50 outlet, or direct power to a load center box with 30 and 20 amp breakers and outlets. This would be a permanent installation, and I'm guessing would be allowed by code.
My preference is for the more permanent approach, but I would be interested in any comments you guys who do this for a living might have.
