2400 Sq ft. shop flooring options
twolabs
Bremerton, WA
I have a new 2400 sq. ft. shop and want to put a solid color down no flakes.
I'm looking for something I can do by myself and in one day if possible. It will be used for normal garage stuff. Any ideas on what to use and what the cost would be?
Armorpoxy
Our SPGX one part polyurea hybrid coating is easy to apply, no mixing, nominal prep, and dries in just hours! Low cost too for a solid color.
stm317
Just an FYI, I think most of these coatings require surface prep (either acid etching, or preferably grinding). That's going to take some time on a slab that big. Then cleaning it up enough to apply the coating too. The coating might be doable in a day, but the whole project is likely to take longer, especially if you're working alone.
T
twolabs
Bremerton, WA
Yeah I was thinking I would etch it do you think that is good enough it is brand new slab.
Armorpoxy
Hi
The SPGX if applied to a standard floor that is not burnished or power troweled can be applied with no prep, just power wash, let dry, apply.
Armorpoxy
If you are looking for a non skid we have a clear/invisible non skid that is like glass bead that gets mixed in called ArmorGrip.
dcg9381
Austin, TX
I have a 2400 sqft slab - and largely had the same question. What product has the fewest prep requirements, is fairly hard, and is resistant to a variety of fluids...
I went with SPGX also - it's also significantly less expensive than doing epoxy....
It'll coat 300-400 sqft per gallon, expect 6-7 gallons. Check their website, but you're over $1k, but way under epoxy costs.
Superwilly
Manitoba, Canada
Can you provide me a link to this product? I also am building a 2400 sq. ft. shop, and am looking for an economical 1-stage alternative to just painting the floor. Is your product available in Canada?
protegeV
DFW
What is the coverage per gallon in this product? Didnt see it listed on the website.
