240V Line thermostat
Climatecreator
CT
I would go with this
https://amzn.to/2QfXaKt
It is designed to control a line voltage unit from a low voltage thermostat. This relay has a built-in 24 V transformer and is compatible with 3-wire thermostats as well as 2-wire mechanical and battery-operated thermostats.
A two pole switch would still be a good idea for service issues as well.....
CC
ForceFed70
BC, Canada
CC
I see nothing but disadvantages for the OP with your recommendation over a simple line level thermostat. The only possible motivation for doing this is because you want to use a fancy thermostat. Not too likely in a garage where the OP is considering going simpler (light switch).
OP: I used line level thermostats for my baseboards in my shop. Different type of heater but similar wattage. They work great - far better than the thermostats integrated in the heater that don't read room temp accurately because they're too close to the heater.
BillK
Beautiful Southern Maryland
I have something similar and just reach up and turn the switch on. But my attached garage only has an 8ft ceiling so it is easy to reach. Why over complicate things unless yours is going to be a lot higher.
mike93lx
Richmond, VA
wmshay6
I don’t know if the heater the op selected will work with an external t-stat. I have this model, https://www.northerntool.com/shop/tools/product_200665094_200665094, and do have it wired to a line volt t-stat.
What stat are yoou using? i have a 5600W heater and want touse a double pole stat, but having a hard time findins a stat locally with a high enough amperage rating. All I can find are max 22A which won't handle 5600 watts, much less the 7000 yours makes.
wmshay6
txvwnut
Bedford, Texas
This one here, https://www.mscdirect.com/product/details/76942564
It’s called a line voltage thermostat but it doesn’t interrupt the supply voltage to the heater. The heater has a contactor in it and that’s what the t-stat controls but it uses line voltage, same as supply to the heater, not a 24vac which your used to seeing in a central HVAC setup.
ForceFed70
BC, Canada
This is making no sense to me. What you've linked to appears to be a regular line level thermostat. The heater is not connected to that thermostat in any way. From the heater's perspective it's no different than someone manually controlling the power by flipping the breaker.
Are you saying that you modified your heater by using a line level thermostat in place of the built in thermostat?
Climatecreator
CT
"The only possible motivation for doing this is because you want to use a fancy thermostat. "
Exactly!
Why limit yourself to the dregs of line voltage thermostats? Fancy thermostat? Why can't you use a good old Honeywell T87 in the shop? It's not like people haven't done that for the last 50 years or anything, you can use a multitude of cheap thermostats (unlike line voltage). There's no need for on / off operation unless you WANT it that way. MANY people do this, like a wood stove, you get it going when you get out there, but others like picking up their phone and setting their shop temp whenever they want.
To each their own, I offer only options. If all you see are disadvantages then just widen your view, it's a matter of perspective.
CC
ForceFed70
BC, Canada
CC
OK, that's great. I can't argue as I pointed out that advantage myself.
However, it's clearly NOT what the OP was looking for and therefor it still doesn't make sense.
