HiPlainsDrifter
- Joined
- Feb 21, 2008
- Messages
- 7
I'm hoping an expert here can clear up my understanding of 240 vs. 120 volt wiring. I'm reading the book Wiring Simplified and there is a statement that is really confusing me.
In describing a 240 volt circuit, it says "If you touch both hot wires, you will be completing the circuit from one hot wire to the other, and you will receive a 240-volt shock. But if you touch only one of the wires, you will be completing the circuit through your body, through the earth, back to the grounded neutral in your service equipment, and you will receive a shock of only 120 volts."
I understand the 240-volt shock from the two wires. What I was definitely not aware of is that I can get a shock from touching just 1 wire in a 240 circuit?? And, if that is the case, can touching just one wire in a 120 volt circuit give a shock? I would think it would have to be, since the single hot wire in a 120 is the same as one of the hots in 240.
I'm trying to just get a better handling on AC wiring, which I don't have very much experience with.
Thanks,
Travis
Thanks,
Travis
