MushCreek
In wiring up my barn, I'll be wiring a 50A circuit for my MIG welder. There is no provision for a neutral- it's straight 240V; 2 @ 120V, and a ground. I have a choice- either wire most of the run with NM, then the last bit (in conduit) with THHN, or I can go THHN all the way. Here's the problem- can I legally (code) use #6-2 NM, using the white wire as a hot? Or do I have to buy #6-3, and just ignore the neutral? If so, it's probably cheaper to just go THHN the whole way (in conduit). I know in some cases you can tape or paint the white wire to indicate that it is a hot, and not a neutral. What about in this case? Or is it a good idea to just go 6-3 and have the neutral there 'just in case'?
Due to the location (on a pole) of the outlet, I need to use conduit and a surface mounted box either way. The choice is whether to run NM to the top of the pole in a J-box, then into the conduit with THHN.
