So my house was built in 1977. It has only one neutral/ground bus bar in the breaker box, and all my 240v stuff inside the house is wired with x-2 cable (6-2 for AC, 10-2 for the range and dryer).
I am going to add 3 240V outlets to the garage. I figured I should use 6-2 wire for the 2 50A outlets I plan to put and 10-2 for the 2 20/30A outlets that I plan to use.
Is this OK or should I run 6-3 and 10-3 respectively? I don't see a point for that since the 2 cables would be tied to the same ground at the breaker panel instead of at the appliance...
I've already bought and run the 6-2 and 10-2 cable and ran it, but I want to make sure 100% that I am doing the right thing before I insulate/drywall...
Thanks in advance guys!
