25 yr. Old Compressor, Rebuild, New Pump or Replace? 2026
gahrajmahal
Cincinnati, Ohio
I’m sure versions of this question have been asked and discussed but the exact title did not show up in my search. 25 or so years ago I replaced my 35 gallon portable compressor with this 60 gallon, single stage “Black Max” compressor purchased from Sam’s Club. It runs off of 220 volts and my father in law ran the wiring and fuse box in the garage along with upgrading another 30 amp circuit to run my mig welder.
I have used the heck out of this compressor from tasks such as nailing new hardwood down in the living, dining room and hallway.
Constructing new deck, front porch, running an air chisel to remove crumbling mortar from our 300+ feet of stone walls. Sanding and painting in the driveway two vintage cars and painting new tonneau covers for new trucks. To everyday filling of low tires, using trim nail guns for interior projects. Grinding and sanding and cutting of wood, metal and other stuff. Even just using the blow gun to clean everyday household items. I just think of my air compressor as a go-to tool for so many things.
Within the last few months I have noticed the tank loosing pressure and the head of the compressor itself leaking oil. I haven’t noticed the tank itself as rusty, thin or leaking. I’m guessing the loss of air is through the compressor as it holds the static charge of around 120 psi. I’ve been ignoring it as it still pumps up fine and I can still use my impact gun to replace brake pads recently and do other things.
I recently opened a new email from Harbor Freight for air compressors, components and air tools. It is there I saw a two stage replacement pump that got me to thinking this might be the path I should pursue. But, with my tank being 25+ years old might this be throwing good money after bad?
Here’s the detail photos.
The last photo shows the soft start relay I added a few years ago to quiet it down and eliminate the “loud bang” it had when starting up. Especially unnerving when standing next to it.
ADKAmateur
Get a NPT threaded plug and put it in the outlet port of the tank. Run it up to pressure and then use soapy water to find where it is leaking. If the tank isn’t leaking through any of the ports (inlet, outlet or drain) then get the HF compressor. You will save a lot of money vs a new compressor.
G
gahrajmahal
Cincinnati, Ohio
I was considering this or similar as a replacement. My goals would be more cfm and quieter operation. Possible adding some sort of radiator between the compressor and tank to reduce moisture in the lines. Something my single stage has had trouble with in the hot and humid summers here in Cincinnati.
Many folks on the “reviews” section have replaced a similar single stage compressor on their similar 60 gal. upright tank and have had to make a larger mount pad and create a new belt guard.
I am curious what you all have done or would do in my situation.
G
gahrajmahal
Cincinnati, Ohio
What an awesome suggestion for checking the tank! I will do this first thing.
The Cobbler
there is a check valve at the tank on the discharge line from the compressor . they can leak allowing air to back flow into the compressor. that is something to check as well
the only reason to plug the outlet port of the tank would be to rule out any leaks in your lines, you can test all the fittings on the compressor without that step. infact I would not do it because now you're not able to check the regulator etc, and that's a common leak area as well
finn
The UP, God's country
Spend some time with soapy water before condemning the pump. If it builds pressure satisfactorily, and isn’t pushing oil into the tank, the rings and valves are probably fine.
The oil leaks point at the head gasket, which is an easy fix, and shouldn’t cost much. Crank seals are replaceable.
I’d look at the check valve and line to the pressure switch first.
I don’t know what type of air distribution and filtering system you have, if any, but that’s a probable leak source too.
ADKAmateur
That is why I would disconnect any lines and plug the outlet port. I would start the troubleshooting by testing just the tank for leaks. Once you have figured that you can work down the line, just like troubleshooting an electrical circuit. Agree that the check valve could be an issue. Any of the piping between the pump and the tank could be suspect but soapy water will show it.
G
gahrajmahal
Cincinnati, Ohio
Here is the exploded view of the total assembly. I never knew there was a check valve between the inlet pipe and the tank. $6.48 at Master Tool Repair, item #22
A few months ago I purchased a natural gas sniffer and also a bottle of "official" bubbling pipe soap to find a gas leak with our gas drier. Now I will know what to apply the soap to. I replaced the pressure switch, set to shut off around #125 when I added the soft start to the motor a few years ago.
Coming off of my outlet port I have a reducer, 90deg elbow going into a Harbor Freight desiccant drier. From there it goes into the pressure regulator that supplies a four-port manifold and a hose reel that has a leaky supply hose. I usually shut off the pressure regulator and in the past the tank would hold that pressure for months at a time. It is only recently that it is draining down the main tank pressure quicker. Say, a week or so now.
Appreciate all the comments!
finn
I added a 3/4” ball valve at the outlet of my compressor, before the filter / dryer / regulator. If I don’t shut that valve after use, everything bleeds down. The leak is, I think, in the black iron pipe at a union above the garage door.
I’m not climbing to the 16’ ceiling to fix it anytime soon. I’m conditioned to shut the ball valve, and remember 99% of the time.
G
gahrajmahal
Cincinnati, Ohio
What does the soft start do?
Originally the motor would kick on with full voltage causing a jolt to the compressor going from zero rpm to full rpm as fast as possible. Kind of like dumping the clutch on a car. With the soft start the voltage is dialed down to say 1/2 for a second then slowly bringing voltage to full 220 volts. All of this takes about two and a half seconds. It is like letting the clutch out smoothly in a car. The motor no longer starts with a loud jolt but smoothly ramps up to speed. Most soft start relays you can set the start voltage and ramp up time. Most outside air conditioner units now have a soft start to them.
larry4406
Northern Virginia
My 7.5 hp 240V compressor makes quite the “bang” when it starts as well. I’ve wondered about adding one of these.
ctandc72
VA
An easy way to check the condition of the tank inside - borrow / buy a cheap borescope camera. They even have 'em that hook up to your phone and they are dirt cheap. You'll at least know the tank isn't rotting away from the inside. Seen that result after rescuing an abandoned compressor that needed rebuilding. Replacing a tank is another ball of wax entirely.
G
gahrajmahal
Cincinnati, Ohio
Another good idea. This fall when wanting to a diagnose rough running engine I purchased a code reader. The reader was suggested by Ryan in one of his front page posts. The company joined the GJ and offered a special which was a borescope and an electrical meter free with purchase of the code reader. Neither of which I have opened to try out. I just didn’t have a project for them. Well, now I do. When I start the work on this project I’ll update this thread with my findings. Hopefully I can post photos of the inside of the tank.
Soft start is an excellent addition to rotating electrical tools. I have soft start on my Bosch table saw, Dewalt palm router and Metabo circular saw. It makes them all much safer, quieter and more pleasant to work with.
slow84lx
Plano, TX
Following along this journey with you as I have a 60-gallon tank with a small pump that I would like to replace for improved cfm.
Love the idea for integrating a soft start for both the compressor and the 5 horse table saw in my shop. The start up is sudden.
Sumboodie
AK
That's a 5hp required pump. Looks like you have a 3hp motor.
5hp motor is around 28 amp draw.
Aileron
outside
I don't see any air intake filters on the compressor in the picture? JMO, you have that compressor tucked away in a spot like I used to have mine. I swapped to a two stage complete unit and couldn't fit it back in that spot. Too tall with a permanty mount shelf that was above it, the foot sticks out the front so its trip hazeard or just in the way. Mines now parked up in the front of the garage but behond a wall for the living area so although quiter since it was a lower rpm it transfers more noise inside the home when it runs. The part of the garage it originally was at stuck out next to the porch around 6 ft or so. Before you swap pumps or change the whole shabang measure twice before you buy. Kicker with mine is I don't use it like i did with the old one. It's more of a burden now and a space killer.
G
gahrajmahal
Cincinnati, Ohio
Sumboodie, this is why I came to the great minds of the GJ 😀. The Harbor Freight ad came around the same time I noticed the oil leakage on the compressor and the leak down occurring. Reading the reviews on the HF pump it looks like many of the purchasers have upright units very similar to mine and have this same concern before buying. Of all of them most do not need 175 psi and after installing the HF compressor, no one has said they had to replace their motor to get it to run sufficiently for their needs.
Aileron, thank you for this helpful information. Looking online at the photos of the Harbor Freight two stage installations I realized I would probably loose my shelf above the compressor due to the increase in size. I have my battery chain saw on the shelf and hanging underneath I have my vacuum brake bleeder and my air chuck for airing tires. I also have my old Devilbiss spray gun hanging, but mostly for the nostalgia.
My compressor has no accommodations for canister air filters which I think would make it quieter, it only has a felt pad over the opening which is a cheap and stupid design I feel. Given how hard I have used it and its age, the designers have the proof of the design working.
Thank you very much for your personal experience. That is the best recommendation! My compressor is in the garage that is under our dining and living room so my noisy compressor can be heard there. My long suffering wife has been silent about this but I know she retreats to another part of the house when I am working with it. Sometimes all day, multiple days in a row. She does reap the benefits of the work being completed and at much less cost than if we hired it out. Plus, hired workers are equally noisy when they are doing a job. Like you, I don’t believe I will be using my compressor as much as I did previously.
I’m still waiting on other GJ members to chime in with other compressor suggestions and complete unit suggestions. I’m cheap by the way!
OccupantRJ
Eastern North Carolina
Be aware that on the HF compressor the fittings on the output pipe to the tank may need adaptation. On two occasions for people I have cut their original fitting and the HF fitting in half and silver soldered the halves together for them to make a suitable adapter. Your findings may be different on your unit. They were both satisfied with their pumps otherwise. Be sure that the pulley sizes are suitable for the pump rpm requirements.
larry4406
Northern Virginia
I would be inclined to take the compressor apart, install all new gaskets (lower gasket at crankcase appears to be the drip source), perhaps install new reed valves, clean/replace the check valve, and take it from there.
G
gahrajmahal
Cincinnati, Ohio
The rebuild kit from the place I found online is $236 the new compressor from harbor freight is $239. I know it would add up to more with fittings, and other stuff. Maddening!
G
gahrajmahal
Cincinnati, Ohio
I’m not absolutely sure as the tag on the motor and the tag on the compressor tank nowhere say five horsepower. My only number I’ve seen is in the first photo in the #1 post there is a large gold plastic logo that says 5 hp. You can see it right above the motor on the belt guard. I have not dug out the manual to get further information.
Do any of you know of another compressor parts supplier besides my initial internet search?
G
gahrajmahal
Cincinnati, Ohio
So I’ve been researching replacement pumps assuming I might be able to continue using my existing tank. I need to have a full day to move the old compressor out of its corner and investigate for leaks and remove the check valve (I’ll probably replace it). Meanwhile I checked out Surplus Center for replacement pumps. They have several brands I’m not familiar with not surprising. I would like to continue with or exceed the cfm of my current single stage. Research says it is just over 10 cfm. I do not need 175 psi. The tank isn’t rated for that anyway. When spray painting with an HVLP spray gun, my current setup runs almost constantly. I purchased a LVLP spray gun and it did let the compressor rest between cycles. Sadly, the gun was impossible to clean and the next time I used it partway through my paint job it had loosened the hardened paint and spit it on my project. The result of the compressor running continuously is it starts to pump moisture into the tank and then your spray equipment. I run a separate air drier, but it doesn’t make a difference when it’s 80 deg. And humid out.
While researching I came across this video explaining single stage and two stage.
Here is another HF pump. Single stage, slightly higher cfm than my current setup. It has air filters, which I would suppose may be quieter than my open port with a felt cover over it. Plus, two cylinders so smaller pistons pumping opposite strokes should makeup more air faster than the current single piston injecting air once per 360 rotation. Plus at $180, cheaper than repair parts and my labor will be installing a pump instead of rebuilding a pump. Right now, this is where I’m leaning.
wazzabie
How well did you maintain this? After each use I drain my compressor of water and leave the valve open. My biggest concern with the tanks is them exploding from rust on the inside.
G
gahrajmahal
Cincinnati, Ohio
Not as well as you have, so that’s part of this conversation too. What complete unit would you buy?
ctandc72
VA
I'm not being flip - you're saying that after EVERY use of your compressor, you drain it and leave the valve open? So if you need the compressor, you have to close the drain valve and wait for the tank to fill? Do you have that much water in your air supply that water actually drains every time?
What kind of PSI are you keeping to worry about a tank exploding?
larry4406
Northern Virginia
I have a Puma brand compressor model TUE-7580.
Mine has performed very well for me. It is a 3-cylinder 7.5 HP 80 gallon unit, two-stage, 24.8 cfm at 100 psi and 22.8 cfm at 175 psi. Pump is all cast iron with insert bearings. It has unloaders and a continuous run option. Probably overkill for your needs. I went big to support a blast cabinet and pressure pot.
The compressor head unit was made in Taiwan.
Link to single stage pumps Puma Single Stage Pumps
Line to two stage pumps Puma Two Stage Pumps
G
gahrajmahal
Cincinnati, Ohio
Larry, nice compressor! I believe it is the brand shown in the video I linked above. At $1200 it is a bit above where I would like to spend, but not that far off from cheaper brands if I need to replace the complete thing. Closing in on 70 yrs. old I don't think my big project days are still ahead of me. You never know though!
G
gahrajmahal
Cincinnati, Ohio
Hey dummy, if you look at the diagram you will see your current compressor has two cylinders running 180 deg. out and not a single cylinder. Surprised no one called me out on that one. I think this design, while compact, has less surface area exposed to cooling air making it run hotter.
G
gahrajmahal
Cincinnati, Ohio
I finally looked up my owners manual. It was on the bottom of the pile which must mean it is my oldest tool since we bought the house. Nothing new my research didn’t turn up but interesting none the less. Turns out it is 31 years old.
I was all set to order the original tank check valve when I thought it might be incorrect. Further searching showed it might be made in China. Another valve popped up from Milton. A USA company and where my tire filling valve came from, so I ordered their version. Machined from a solid piece of hex brass. That way when I take the original one out to visually check the tank and check the valve, I’ll have a replacement at hand. I do think that it is the leak down culprit.
Also, in case I might need a new tank I decided to look at Facebook marketplace and Craigslist. I was surprised by how few compressors were on Craigslist near me. Maybe 1/2 dozen. On Facebook if I was to sell mine as is I should list it for $700 or more. I couldn’t believe the crappy compressors, very old, no belt guard and looked to be rode hard and put away wet. That’s not to say anybody will buy those listed, but there were probably 30 or more listed there, upright compressors with 60-80 gal tanks.
Thanks again for all the suggestions.
wazzabie
Every time there is water vapor that is expelled out after use.
G
gahrajmahal
Cincinnati, Ohio
While I was going through my users manuals looking for my original compressor manual, I came across an automatic tank drain I once had installed on my compressor. The idea was that once a sufficient amount of water, around one cup or so, would accumulate it would activate the drain automatically. It had a long hose which I routed under the closed garage door and extended a foot or so into the driveway. I had seen them before at shops I worked at and was startled a time or two when the drain line would give a quick blast of drain water. I removed it and replaced with a ball valve as it quickly quit working.
