Alright, My buddy is attempting to "rig" up a PTO generator hookup at his house. While I don't know much about AC, I think I know enough to determine when something doesn't feel right.
The setup...
200amp service in to a outside panel located on a telephone pole. Inside are 100 amp service for house, 100 amp service for the new shop.
The Goal...
To be able to run the generator in the shop so the noise isn't right near the house. Have a little power for the shop to tinker around (shop lights, etc), but mostly to service the house.
The problem
He wants to backfeed the system through the shop panel and kill the 200 main breaker on the pole which in theory would work, but I know it is a big no-no. Ideally i'd like to come up with the most logical and cost effective way to set this up so no one gets hurt
The panel on the pole does not have to exist anymore if that makes it easier, but there would still need to be a way to split the 200 amp to 100house/100shop.
Again, the generator is primarly for the house. The part I am lost on is whether a 25kw generator that says it is rated at 100amp, but I guess we need to make sure it has a "full power" plug
The Solution...
I was thinking of suggesting a 200 amp generator switch between the meter and the panel. Then Run a line from the transfer switch to the shop to make it a done deal? Thing is.. those transfer switches are expensive at 200 amp. It should be a manual switch too.
Downside... you won't know when the power does come back on. Also the only reason you would need a 200amp transfer switch is because of the incoming service. The other problem is we would need to have the power cut, and the power turned back on again to install the switch.
Solution 2
If the disconnect was in the basement of the house, it would only need to be 100amp, but then you'd have to run a cable from the house down to the shop for the generator. This does take care of the primary concern, and has a cheaper disconnect, but... doesn't take care of the shop.
I'd assume there would be 120 spots on the generator too which could provide any power, but that would still leave the shop lights.
As you can see I did put some thought into this. I'd like to see what you guys think / suggest. All thoughtful suggestions are appreciated!
The setup...
The Goal...
The problem
The Solution...
Solution 2
I think 25kw will be more than plenty like you said.
