26 VAC leakage?
stewart
long island NY
Hello
I've seen this before in the old house and I'm seeing it again in the new one. On circuits that have been shut off at the breaker, I can read 26 to 36 VAC across the black wire and neutrals or earth ground. Anybody have input?
Thanks Stewart
Ironcrow
Arizona
Yes, digital voltmeters can read bleed-over from adjacent wires. There is hardly any current available at this ~30 volt level. Even the impedance of a cheap analog volt meter will pull the voltage down to nothing.
ddawg16
S. California
Phatom voltage is not exactly the right description....
What you are seeing is 'induced' voltage. This is a good example of what happens when wires pass parallel to each other over a distance.....I have seen as much as 80-90 Vac....
The good news is that it's a low current....if you grab the wires, in most cases there is not enough current for you to feel anything.
TurnipTruck
Southcentral Alaska
I see this at the plant all the time. I recently had a problem at work where a 120Vac relay was intermittently energized by induced current when a strobing DC signal RUN IN THE SAME 1000' CABLE AS THE AC POWER caused mystery shutdowns. I measured 80+ Vac with the far end of the AC wires disconnected.
LoneGunman
The Gunshine state
That's why I still use an old school "wiggy" (solenoid operated tester) as my main tester, no reason to break the expensive Fluke out for 99% of jobs and the "Wiggy" won't read low current voltages because the solenoid is using the current.
