$275 for big ol' lathe in CA
Packard V8
Spokane, WA
A benchtop lathe would usually sell for 2X the money, because not everyone has the space and a construction battalion to move and install the big dog.
jack vines
Maui
Upstate NY
I just looked at the photos in the second link. The trailer they are using to transport that lathe looks far too small to safely do the job.
Maui
VocaTexas
I wouldn't mind having the pedestal grinder, too. Love the lathe...
chrispyny
albany, ny
Lets say moving a unit like this is free by a wrecker, lets say you have a huge bay to place this in, the knowledge and know how to restore it, most people still don't want it.
Why?
Because, as a machinist, one sizes the machine for the job. You don't scrape a dirty kitchen skillet with a jack hammer.
And you don't turn a small workpiece on a 3,000 lb huge *** lathe.
I hope this guy has a need for such a big lathe.
2oolhound
BC Canada
I knew a farmer with a lathe around that big. He made up a lot of drive shafts for me. I'd buy long ones from a junk yard and he'd cut them down for me.
That thing is a monster.
Mike W.
I don't agree Chrispy. I did tooling work for years and the smallest lathe we had was a 14 inch swing and we had no problems doing small work except for the rpm which was really no problem. And this lathe is only 10" swing. As far as the bed length, if you got the room a longer bed like this one is a plus, if you ever end up with a long work piece.
chrispyny
albany, ny
Oh trust me, i'm speaking in general terms. My dad is a retired machinist. He's 73 and made chips for 40+ years. First for a contractor that was a supploer for the DOD, then ultimately retiring from the Watervliet arsenal. That remark was a combination of our opinions.
For example, here is my 13" South Bend i'm doing a full restore on. 1982. Xame out of a votec school at auction last year. Near mint. No wear. It has a 6' bed. I'll NEVER use all that bed, but i have it! And i'm doing a painstaking nut to bolt restore on it as well!
Gunk in headstock, yuk.
Carla
MEMBER EMERITUS
I'm rather surprised at the bit of negative commentary here.
This old lathe appears, from the refinishing done on it, and the plated bits, to have been someone's 'pet' at one time. From that, its most likely to be in generally good serviceable condition (otherwise, its quite unlikely that anyone would have invested the time/energy in appearance work)
This one appears to be of 1895-1910-ish vintage, approximately, the era of slow spindles and forged carbon-steel tooling, an extremely inefficient machine by more modern standards. That said, once levelled-up, it may well be capable of holding .001-ish on dia., with careful operation, adequate for the generality of repair or hobbyist work. (way wear is a question mark.....its possible that this machine's history could be from a plant maintenence shop where it was little used, so it would have come down through the years in surprisingly good condition......thats a 'maybe', of course, and only with a good first-hand inspection could one say)
As a 'hobbyist' or small private repair shop machine, this one has some potential value, if one has the building space available. At that first-cost level, if it does one useful job in, say, two years time, its a cost-effective investment. (it appears to be a 16 or 18" swing machine, a good convenient size to use if one were to remove its raising blocks, and reserve them for re-installation only as might be needed for larger dia. workpieces)
A probable very good use for this lathe would be in the field of ornamental wood-turning, on a hobbyist or artisan level. It would do the work usually done on a much more expensive Oliver or equivalent patternmakers' lathe, just not nearly so quickly, with its slow spindle. I'd think this machine might find a good home with a woodworker who would like to experiment with a bit of wood-turning which would need its size and relative rigidity, such as doing ornamental columns.
In short, that one appears to be a potentially excellent deal, for the right person.....its a useful capability, and well worth putting back to work.
cheers
Carla
Provincial
Near Salem, OR
The slow spindle speeds of old lathes are the biggest problem. You need high spindle speeds to turn small diameter parts, especially when using carbide tooling. It is hard to get a good finish at the slow speeds.
alskdjfhg
Houston TX
You dont need a construction battalion to move this lathe. Ive moved much larger by my lonesome, me being a scrawny teenager and all. Moved WAY larger when Dad was helping.
And as far as "restoring" it, its a single wall apron cone head so there is hardly anything there to begin with. And IMHO unless your scraping the machine back to original specs, you can't call a paint job and polish a "rebuild".
If your at all handy you can fix about thing that could be wrong with it. Although you may need another lathe and mill to make something for it.
Dennis Leigh Henry
South Central, IN USA
Ted Pfluger / SBLatheman will have the quick change gear box plates...
