blazemaster83
I answered a free ad on craigslist the other day for this. A gentleman was moving and had a ton of old equipment he needed to get rid of. I managed to be the first one to email him so I got a call. The tires are in great shape but the trailer lights did not work so I had to buy a magnetic kit to get it home. I didn't have much time to look it over when I showed up, just hook up and go. It made the 40 mile trip fine. The previous owner said his father found it abandoned on some logging road and filed a fair market value estimate, and a found property claim form(i have both). Then it sat for another 8 years before they gave it to me.
Once I got it home I gave it a much needed pressure washing and cleaned out some mouse nests. It is a Deutz F3L912 air cooled diesel and a lima 27kw generator, 4200 hours. It has a transformer so I believe it should supply single phase and 3 phase. It has 2 large fuel tanks I would guess at about 30 gallons a piece, both half full. The trailer could use some freshening up but the generator seems in pretty decent shape.
I pulled a battery out of one of my other cars, made sure the fuel rack was free, got something to cover the intake in case it ran away and started messing with the controls. I thought it was missing a start button since there was none, and there is a hole in the control panel that looks like a switch was removed but it fired up when i moved the switch to the run position, on the first crank.
I am a bit new to this size of generator, the only other I have used in the past is a simple 5.5kw coleman. Once I got it fired up and replaced some springs for the throttle linkage, it ran quite well. The generator side however only seemed to be putting out 110v per leg of 3 phase. Is this something that I can adjust with the voltage adjust knob? I would like to make sure this thing works before I get into changing filters and buying stuff to get it up to snuff.
Has anyone dealt with a similar gen set? I am not sure what to do other than checking voltage and connections.
