garagelogician
I have an attached compact 3-car garage. Basic footprint is about 27x19. Ceilings are about 10'-5".
Walls seem to be (mostly?) insulated, but I don't know about the ceiling with the exception of the part where the upstairs bedrooms cantilever over the garage about 4-5 ft. Garage is fully sheetrocked with textured ceiling and two light bulbs near the one side that currently have 100w equivalent LED bulbs. There is one outlet on the wall, and one on the ceiling for the overhead garage door opener.
Needless to say, this does not cut it for my needs. I do repair/maintenance work on my personal vehicles, as well as other misc. projects with some possible woodworking. Primary woodworking space is planned for a 12x16 shed out back, but certain projects may outgrow that space, so they may have to move into the garage.
I have plans to setup some folding/mobile workbenches and will have other items on wheels to make the small space as flexible as possible. I plan to purchase a 4-post lift. It will sit in the 3rd bay (to the right) and will likely store a small utility trailer when not being used for automotive work. The lift will stay there for oil changes or other work when I don't need to have much access to the right side of the vehicle, but it will be moved to the center of the garage for bigger projects.
Garage doors will be converted to high lift tracks mounted as close to the ceiling as possible, with jackshaft openers.
First priority is getting more outlets installed, I will run a subpanel to the garage so that I can add circuits as needed. I plan to eventually install a mini-split A/C, and will need 240v for a compressor and maybe a welder. I am pretty green with electrical work, so I would likely hire this out or get some help from someone more knowledgeable until I learn more.
Is it worthwhile to rip out drywall and mess with the insulation to install wiring? Or should I just surface mount everything and run EMT? I'm not opposed to surface mounting, I would probably just run it up high and then make drops to the outlets. I will likely only have a few wall-mounted cabinets in certain areas, so that should work fine.
With regards to lighting, I was considering the slim surface mount LED flat panel lights that have the integrated drivers for easier installation (and to not give up any ceiling height for the lift) like these. However, I don't believe the cost and the added hassle of snaking wires to be worthwhile.
Instead, I am now considering the MaxLite 4-ft 2 bulb fixtures with 4,000K LED tubes placed in such a way that they won't interfere with the two planned lift positions. Can I just run surface mount conduit to these units?
I see the bulbs listed in the "Best Light Fixture Ever" thread, but I would like to have the capability to add dimmers and/or motion sensors. Are there any comparable bulbs that are dimmable, and compatible with a dimmer/motion sensor like this?
Garage layout is attached, approximate planned light locations are shown in red. I need to evaluate the right side light locations more with the garage track, but don't have the time for it right now.
Thoughts/advice?
Thoughts/advice?
