28x36 With Lean-To
Fechmup
Southeastern De
I first found this forum a few months ago when I was looking for garage ideas. I didn't even know what size to start with. After writing a list of needs and wants, I honed in on what needed to be built... An 80'x120'....
Back to Earth.
I received proposals from several companies in the area to build a 24x32 workshop. At the time, I wasn't sure if stick built would be the way to go, or post frame construction. I like stick built for a lot of reasons, but in the end, post frame was about 25% cheaper among the contractors we received proposals from.
By the time we had selected a contractor, I think we were on our 15th update/revision. I'm sure I was a pain, but I tried not to be.
The final drawing was settled on 28'w x 36'd with a 10'x36' lean-to on one side for a dog kennel and firewood storage. I really wish I had room for the building to be 40' deep, but with 20' setbacks from the rear, and 15' from the side, I really couldn't do much more.
Another constraint I had was the HOA.... I was the test case for my neighborhood of 32 homes. We are allowed to have garages, but I was probably pushing the envelope for the more 'controlling' neighbors. When I sat down to put the arcititural review committee application together, I went over all the deed restrictions carefully.
I knew I wanted the roof pitch to match the house -- 8/12. I knew the roof height of the building couldn't be higher than my single story house. I also wanted a 10' tall garage door, which meant 12' walls. The gutters on the house at 11', and the yard slopes back in the yard, so that would be easy enough to hide. I also think the garage door looks scaled down a bit because I made it 20' wide.
The HOA required that I use vinyl siding and asphalt shingles. Fine.
My application was ok'd and we were underway. We're about 6 weeks in and the insulators are here today. I'll backtrack with some pics first.
F
Fechmup
Southeastern De
So I'm going to skip ahead to today.... The insulators were here and gone, but I'm pretty sure there's a problem. My ridge vent is completely sealed off. I think the insulation should have been installed down where the liner panel is to be installed.....I really wish I could upload more than one picture at a time. Tired of transferring pictures from one device to another.
msgross
Central PA
In my house the ridge vent is view able, and there is a channel near the soffit for the air to travel. If they sealed that off and you are closing in that upper area then I don't see how air can travel.
I'm building the same size this month only with 10ft walls...
F
Fechmup
Southeastern De
My hope is that there's a vent panel behind the insulation that will allow air to travel up from the soffits to the ridge vent. I'll investigate tomorrow.
I'm going to try tapatalk, to see if it facilitates posting pictures, so I can have a little fun posting pics and sharing my thoughts and ideas---- the nitty gritty stuff.
vvk645
olympia, wa
when I had my old shop built a few years back, there was a gap in sheeting at the very top of the ridge, don't remember for sure, may be 2-3 inches and the ridge vent covered it so it would ventilate properly.
Anyone have an opinion as to the insulation over the ridge vent?
