radrush
Is it the general consensus that if you want a decent quality 2hp air compressor that runs in the range of 6-ish CFM at 40 PSI and 5-ish CFM at 90 PSI you must be willing to spend in the neighborhood of $500 to $600?
This would be for non-professional use. Seeiously...I should probably get that RIDGID triple stack thing at HD but it's specs reek of being mostly wishful thinking. And for a couple hundred more I could pick up something that would probably out last me and had at least the potential for occassional auto related air tools.
Setting aside the various arguments of belt-drive vs direct-drive and oil-free vs oil-lube something like these:
http://www.aircompressorsdirect.com/Puma-PK5020-Air-Compressor/p589.html
Or
http://www.amazon.com/dp/B00QFH5NCM/?tag=atomicindus08-20
Or
I recently bought the 29 gal HF oil lubed compressor and don't regret it one bit. It has done everything I have asked of it- impact guns, air ratchets, air/hydraulic rams, and even HVLP painting.
