I have used a ton of the redlink wireless zoning on retrofit. The issue I have with their dampers is not of quality, but that the actuators are bulky and much more complicated than the aprilaire's dampers. When aprilaire/lennox came out with their new dampers with the external position indicator it really helped me do mostly aprilaire dampers when they have the sizes we need. Also, aprilaire has a slick retrofit 6" damper that is inexpensive (less than $30 wholesale) and has a very low actuator profile and simple, simple installation. We do tons of retrofitting on existing basement system that use rectangular main plenum (below the ceiling joists) with lateral runs in 6" (which is 99% of our market). A typical installation requires 20+ individual retrofit dampers, and then you group the dampers into zones.
From there, we used the variable speed Lennox Furnaces, that allow for adjustable air flow to each zone. Each zone can be adjusted in 10% increments starting at 25% of total air flow up to 100% of air flow. Example: on a 3 ton/1200 cfm furnace blower (Lennox Only does this), minimum air flow is about 300 cfm. Air flow can be adjust in 10% increments for EACH zone.
With the advent of Lennox's modulating furnaces, it's a perfect match. The tricky end is the Air conditioning. Currently, the nicest A/C unit Lennox makes is only a 2 stage, and only cuts to a 2/3 capacity on first stage, so it will cycle the a/c. BUT.......Lennox is coming out with a full modulating A/C unit, and that will allow for the A/C unit to slow down matching indoor air flow.
At the end of the day, we use a combination of 3 or 4 different brands of zoning depending on the actual circumstances. In this case here on this forum, the best option is to just spend a bit of money on actuators.
On really high end installations, where no bypass is wanted by the client, and being quiet is key, we use a really nice 99.99% sealing damper with external actuators. My cost on that type of damper setup is almost triple, and its much more complicated to install.
Have you done any Arzel zoning systems? Nice setup for retrofit, dampers are controlled by air pressure instead of electric. They also have an interface to run it with a Harmony III board.
I'm waiting for a new zone control designed to work with the icomfort thermostat, I really like the icomfort compared to any other stat but it ***** that you can't offer it with a zoned system yet.
