Okay, so I began building my "ultimate" workbench this week - utilizing my 2x4 Basics Legs+Shelf Links Kit I purchased. My "vision" was to build a 4'x8' workbench - like I've seen in images such as the ones below . . .
I have the frame of the bench put/clamped together (no MDF shelves/top yet), and I am shocked by just how wide 4 feet actually is. I mean, the bench will be set against a wall - and when I stand in front of the frame, I can barely reach past 2.5 feet across. I consider myself a "regular" sized guy - 5'8" with a normal arms-length/stretch . . . so I'm wondering how any "normal" sized person who builds one of these monsters would be able to reach anything that happened to be situated toward the rear of the bench.
Of course, I know I can simply reduce the length of the bench to 3.5' or 3.0' - which I may experiment doing just that (being that 2x6s and 2x4s are generally not terribly expensive (if I need to pick up a couple more)). I do, however, like a nice large workspace to be able to utilize/take advantage of - and I have a "envisioned" plan to expand the bench down the length of my garage wall - with customized (DIY build) a miter saw station in the middle. (note: I have a 12" sliding compound miter saw).
So, I suppose the obvious solution is to simply cut down the length of the boards .... but I thought I would throw my situation out there to see if any of you might have any thoughts, insight, suggestions, etc. (especially from those of you who may have built a similarly sized bench).
THANKS ... Looking forward to any feedback you can share/provide !!!
TOM
