DugT
I'm considering getting a Harbor Freight 3/4" Pittsburg Torque Wrench for lug nuts and also my 162 ft lb caliper bolts. Why not? Is its 26" length too long? Is its 24 tooth ratchet too crude?
I like that it is 26" long which is good for leverage. It is beefy, 50 lbs to 300 lbs so it shouldn't break under my modest use. If it does break it has a lifetime warranty.
My Matco 10-100 ft lb 3/8" torque wrench's settings lock has failed. I can still use the wrench but I need a bigger wrench for lug nuts and my brake calipers (162 ft lbs.) A 1/2" wrench is usually used for these applications but the HF 3/4" is only $65 with the coupon so why not go big?
By the way, I believe the HF wrench is made by Tekton because functionally it looks identical. I can't post links yet but these are the wrenches.
HF PITTSBURGH 3/4 In. Drive Click Type Torque Wrench
TEKTON 3/4 Inch Drive Click Torque Wrench (50-300 ft.-lb.) | 24350
