3/8 6mm impact socket ... do I need?
BWWgarage
My lovely wife grabbed me a 3/8 capri 8-22mm impact socket set(to go w my m12 3/8 stubby). I have them on a Hansen socket organizer so 7mm and 6mm spots are open. I don’t enjoy looking at the empty spots but I’m cheap enough to not buy only to fill a spot ... can anyone convince me I need a 6mm (and 7mm) 3/8 impact socket?
Thanks
1320
Arizona
The only time I've ever used a 3/8" drive 7mm socket is when I wanted to use a cordless ratchet and only had a 3/8" drive version.
KnurledNut
n/a
I hammered a 6mm onto a rusted 1/4" and was able to remove it. I wasn't too worried about it splitting due to the extra beef of the 3/8 drive. It was chrome but an impact socket would have been even more forgiving.
We are talking a $4 socket here. I'd rather have and not need than need and not have.
Tchicken
THE Motor City
Funny find this one - since I don't use an impact gun, or cordless ratchet, I am qualified to opine as I got that free, empty space that requires something to fill it. So OP, if you use one, buy one. If you don't, don't.
YesIHaveAHammer
7mm is M4.
If you have any socket in that size, in the same location, and it's 6pt, then no need to get an impact one.
epiphany
Would count different. You don't have 2 slots over but 4 slots missing.
6mm, 7mm, 23mm, 24mm, small extension, universal joint.
o_O
drmarkr
Tucson
I've never used a 6 or 7 impact....much less a 1/4" version.
But those empty tines might bug me bad enough to just put some spare chrome in there to fill the void, lol.
Brandon_Lutz
Forest Hill, Louisiana
Thanks
I think Capri tools saw your thread and decided to feed the OCD :LOL: (I understand it all too well haha)
Capri Tools now offers 6 and 7 mm impact sockets.
BWWgarage
Craziness. I was thinking I was buying texton to fill those spots. It’s a sign from the tool gods to fill those spots.
What’s funny ... the Hansen trays with spines aren’t really made for impact sockets. I started filling from big to small and when I got to the 8mm, it wouldn’t fit (9mm was squeezing it right too much), so I had to move the 8mm over to the 7mm spot. I didn’t sleep well thinking about it. I think a snapon epic 56 would resolve it. Ha.
Hannahranga
Definitely worth having 3/8 6/7mm sockets around imho it's more convenient to use your already out 3/8 tools to get the odd hose clamp etc. I'd only go impact over chrome to make it match
bwringer
Indianapolis
I have 20 and 23mm sockets for the same reason. Just gotta fill those gaps, or it'll make me crazy. They sure are shiny, and always will be.
In this case, I'd wonder if I could do a decent job of just cutting off the end so I don't have to look at the empties. Or removing or replacing the markings so I could put something more useful on the same pegs.
Black300zx
Elkton, Md
If you want an excuse to buy something to "fix" the empty rail positions, buy an Ernst socketboss rail set for your impact set, label them to match your socket set, and fill any empty positions with impact universals in your most-used sizes.
Fedwrench
Valley of the sun
Has anyone used a 6mm socket for anything? I think I read somewhere that 6mm is for hose clamps :dunno:
7mm is quite common in older GM products.
This is Garage Journal where an empty Hansen Peg can cause sleepless nights so, you might have to get them. I avoid Hansen trays because, the Hansen peeps don't know what size sockets I use :bounce: Vim magrails, the cure to empty peg syndrome:lol:
KnurledNut
n/a
Looks like 6mm is the wrench standard for a 3.5mm bolt. Most of those would probably use a screwdriver type head but there does appear to be some specialty fasteners that use a standard hex head or a combination head.
Beerhippie
Far NE Oregon
Electrical connection boxes on German motors.
7mm seems to be the most common metrical hose clamp I come across.
pbon
I DIY on German cars and encounter 6mm regularly and 7mm occasionally but nothing for which I need 3/8 ratchet size or impact socket strength or durability. Plus 3/8 drive and impact spec is physically large compared to 1/4 chrome. They would be my last choice for a 6mm or 7mm nut or bolt. I buy just about any tool I want, but would not buy these and to the extent I have them, I can’t recall ever using them. I have plenty of 1/4 drive 6 and 7mm chrome.
Ohio Andy
Columbus, Ohio
If you ignore your garage journal OCD tendencies to want to fill every spot, I think the real reason for filling those with 3/8 is if it is strictly a 3/8 set and you think you can maybe not bring an extra 1/4 set because you have those smaller sizes and the 3/8 set.
Or if you happen to be where you don't have your quarter inch set with you. But you do have the 3/8. You still can go down to some of those smaller sizes that you didn't think you needed if it happens to come up
BWWgarage
Fine points. For my uses, I doubt the complete impact set ever make the travel bag.
