I accidentally fell into owning lots of torque wrenches, wasn't in the plan, just happened..............
Here is my collection..................
Front and center, Seekonk 1/4 drive 30 to 150 in/lb micrometer type
Just behind the Seekonk is a Sturtevant-Richmont (SR) CCM150I interchangeable head micrometer type (with no head) 30 to 150 in/lb
Front right is a SR CCM150F interchangeable head micrometer type with a 1/2 drive head, 30 to 150 ft/lbs
Front and left is a SR CCM750I interchangeable head micrometer type with a 3/8 drive head, 150 to 750 in/lbs.
I have 1/4, 3/8 and 1/2 drive ratchet heads for the Sturtevant Richmont CCM series torque wrenches and can swap the heads between the torque wrenches as needed.
Second row left side, is a Snap-On dial type "Torque-O-Meter" 1/2 drive, 0 to 250 ft/lbs
Second row right side is a Snap-On dial type "Torque-O-Meter" 3/4 drive, 0 to 600 ft/lbs with no extension handle
Middle, third back is a Gedore 4507, German made 5 to 40 ft/lb with a 1/2" female square drive, micrometer type. The male push thru square drive plug is missing, but I am ordering them 1/2 to 1/2 and 1/2 to 3/8
Left side, third back is the new Precision Instruments 1/2 drive flex head split beam C3FR250F, 40 to 250 ft/lbs
Just behind the Snap-On and Gedore... is the new PI 3/8 drive flex head split beam C2FR100F, 20 to 100 ft/lbs
To the far right, past the PI 3/8 drive, sitting on top of the reddish box is a Utica interchangable head 10 to 150 in/lb micrometer type with both 1/4 and 3/8 ratchet heads. I have seven of the torque wrenches but only one of each of the heads.
Red box to the left is a early '70's vintage Craftsman 3/8 drive beam type, 0 to 50 ft/lbs
Blue box is a early '70's vintage Craftsman 1/2 drive beam type, 0 to 150 ft/lbs
Far right in the plastic package is a '90's vintage Craftsman 1/2 drive beam type, 0 to 150 ft/lbs
Also far right is a '90's vintage Craftsman 3/8 drive beam type, 0 to 50 ft/lbs
To the left, the electronic meter in the package is a Craftsman 44599 electronic torque measuring system, 0 to 150 ft/lbs
Last but certainly not least, is a English made System Norbar 3/4 drive (push thru square drive plug) ratchet, clicker type, 370 to 1100 ft/lbs with its metal case and extension handle. Over five feet long and has a nearly two foot extension handle with it
Charles
