3/8 pneumatic impact
mikeatrpi
Home
I'm looking to purchase a 3/8 impact air tool. I'd like to get one with enough "guts" that it could be used for lug nuts, brakes, etc - but reserve the bulky 1/2 wrench for crank pulleys and axle nuts - at my home garage. Budget is approx $150.
Is the Nitrocat 1355-XL the bee's knees? How does the IR 212 measure up, and is it actually made in the US? Thanks!
mrjaw14
Nashville, TN
I looked at the IR212 and wasn't impressed. If you want IR, go with the Ti2115 I think it is. That's got some balls. For cost reasons, I actually bought a HF earthquake for my 3/8" gun. supposedly rated to 300ft lbs. Those seem to have a favorable standing here on GJ
M
mikeatrpi
Home
Ti2115 - is about $75 over my budget. Is it made in the USA?
I see its a "twin hammer". The Nitrocat is a "twin clutch". Is one better than the other?
reptilezs
my 3/8 gun is from astro, the blue one. rated to 300 ft lb and has a twin hammer.
reptilezs
AIRCAT® 1150 model impact wrench uses a Durable Twin Hammer Mechanism.
The Rugged and Reliable Twin Hammer mechanism creates a higher speed and faster blow per minute (under a load) impact. The Twin Hammer is best suited for all-around automotive maintenance. The twin hammer design has the hammer able to slide and rotate on a shaft, with a spring holding it in the downwards position. Between the hammer and the driving shaft is a steel ball on a ramp, such that if the input shaft rotates ahead of the hammer with enough torque, the spring is compressed and the hammer is slid backwards. On the bottom of the hammer, and the top of the anvil, are dog teeth, designed for high impacts. When the tool is used, the hammer rotates until its dog teeth contact the teeth on the anvil, stopping the hammer from rotating. The input shaft continues to turn, causing the ramp to lift the steel ball, lifting the hammer assembly until the dog teeth no longer engage the anvil, and the hammer is free to spin again. The hammer then springs forward to the bottom of the ball ramp, and is accelerated by the input shaft, until the dog teeth contact the anvil again, delivering the impact
- Faster hard hitting impact (1,400 Blows Per Minute)
- Durable, Rugged and Reliable
- Recommended for all-around automotive torque applications
NITROCAT®1200-K model impact wrench use a Smooth Powerful Twin Clutch Mechanism
The Hard Hitting Twin Clutch mechanism creates a high torque initial impact.
The Twin Clutch design uses a hammer fixed directly onto the input shaft, with a pair of pins acting as clutches. When the hammer rotates past the anvil, a ball ramp pushes the pins outwards against a spring, extending them to where they will hit the anvil and deliver the impact, then release and spring back into the hammer, usually by having the balls "fall off" the other side of the ramp at the instant the hammer hits. Since the ramp need only have one peak around the shaft, and the engagement of the hammer with the anvil is not based on a number of teeth between them, this design allows the hammer to accelerate for a full revolution before contacting the anvil, giving it more time to accelerate and delivering a stronger impact.
- “An 800 lb Gorilla”
- Slower but harder hitting impact
- Recommended for high torque applications
skruft
I have never seen anyone do lug nuts with a 3/8 air impact - maybe stay with 1/2 for that.
I have an older IR 3/8, with a blue plastic shield, not sure of the model but it works fine. I don't use a 3/8 air impact enough to know about how well it lasts. I got the IR because I know their 1/2 are good.
GSteg
Earth
I have the Snap On MG325 and the IR 2115TiMax. Love the IR since it's been more reliable, but both have good amount of balls.
Mazdaspeed
The latest 3/8" impacts will do lugs no problem and is a fair bit lighter so there are some benefits to someone doing a lot of tire changes.
GSteg
Earth
It's assembled in the US. You're going to have a tough time finding a consumer impact gun (for the price anyways) that's fully made in the US. Even though Snap On lists the COO of the MG325 as USA, I know for a fact the bearing inside was from China. I rebuilt mine and was surprised to see a China stamp on it.
M
mikeatrpi
Home
Thanks all. A lot of votes for IR 2115; no mention of the Nitrocat. Darn, I was hoping to save some cash! You get what you pay for.
bcradio
New Mexico
That is all I use for lug nuts and I would not want to use a 1/2" anymore for them at all. I have the 3/8" Earthquake and it takes off all lugs I've encountered with ease.
So yes, save yourself some cash and get the Earthquake IMO
outdoorsman310
DE
150 budget? probably a harbor freight earthquake. I would not put wheels on with it though. otherwise mg325. I dont put wheels on with that either
firebox40dash5
Pretty sure my 2115TIMax is hecho en Chine... I've got a boot on it pretty good, so I'm not going to check, but I'm pretty sure it is. That aside, you're not likely to find Made in USA air tools for a good price anymore. :( At least it works quite well. Check around for the Matco version used, I've seen them go cheaper than the IR version for some reason.
Just don't expect it to do awesome at lug nuts or caliper bracket bolts on bigger stuff, like Ford and Chevy trucks with the huge M14 threadlocked bolts or 22mm lug nuts. Sometimes it'll zip them off, sometimes it won't. I usually start with my cordless and if that won't do it, just go right to the 1/2" air gun.
Halfdawg
Blue Point AT370 is a bad *** 3/8ths gun. I bought mine used off the truck 8 years ago and it has been my go to every since. I just added a MG325 so I could leave a 3/8ths gun in my service truck and so far I'm still torn between which on stays in the shop and which one goes to the service truck.
Marlin
Nope, it probably came from out North Carolina plant, or if it is a bit older it cam from Pennsylvania.
Marlin
really? I think that is really neat that these are still being made here.
Yes, not all components are made in the US so we have to label it "Assembled in the USA" but a good portion of the parts are made here and they are currently assembled and tested in our factory in Southern Pines, North Carolina along with several other of our tools.
M
mikeatrpi
Home
Thanks everyone for the advice! Marlin especially for the inside scoop!
Looks like Amazon has the 2115 Q TI Max for $239. I assume I want the "Quiet" one, right?
I'll pick that up and a flex-zilla 2 foot whip. This is going to be great! Thank you!!
Mazdaspeed
Yes, the quiet one is worth the extra few dollars for it. I have the Ti2135 (purchased first) and QTi2115 and appreciate the extra noise reduction of the QTi.
country83
The AT370 just came out a year or two ago, and it runs like a scalded dog. You must be thinking of a different model.
