3/8 ratchet reccomendation
gdpolk
This is the set of features I'm looking for. What's a good quality ratchet that'll meet my needs?
  • <$75
  • 3/8" drive
  • at least 80 tooth for a nice small arc
  • flex head that DOES NOT lock into those irritating pre-set angles
  • the thinner/smaller at the head, the better
  • good quality, it doesn't have to be top tier but I'm expecting better than Harbor Freight stuff too.
  • Lifetime warranty that's from a company that actually honors it
  • All metal - no built up plastic handles, soft grips, etc. Chrome or industrial finish makes no difference but I want something that can be wiped off and put away and be just as good 50 years from now as the day I bought it. Plastics become brittle with age and rubber/foams become unstable and fall apart. I just want plain old metal.
  • New or used makes no difference to me. I'd rather have a $50 investment in a top tier $100 used tool to use than a $50 investment in a $50 tool to use. That said, I have no aversion to buying new tools either.
Thanks in advance for your options.
AmishFury
person says no soft grips, let's recommend a set of soft grip ratchets...
you could always go with a FLF80... you can find them for under $75 used without much difficulty one on ebay right now for $66
Citation
Indy
If you can accept a 72 tooth design, for $25 the Home Depot Husky flex head is basically a non-locking Gearwrench design for $25.
Banana Man
Los Angeles
Snap On 72 tooth. Lightly used off eBay. You might even find a new one for around $80 bucks if you keep checking the "newly listed" Snap On listings, as the best deals get swooped up quick.
Mr.Nutcase
USA
that does not exist? they are 80 tooth 3/8, the 1/4 are 72
kctyphoon
Jersey/Staten Island
Hey, don't know if you noticed Sherlock - but if you actually read the post BEFORE mine, the OP declared "looks like we have a winner" -
which is why I wrote, "if you can part with ANOTHER $25" meaning,-
(in addition too / along with / after your initial purchase) as is, "if you already made a decision and found what you want, this is a great buy on two MORE ratchets, which still happens to fit within much of your 9 point wishlist, and for $12.50 a ratchet at that.. -
but then again, I could have always posted something much more constructive like "how bout a used snap on off eBay" cause it must take a person with a real superior intellect to think that one up.. :thumbup:
Banana Man
Los Angeles
OP:
"3/8" drive
flex head that DOES NOT lock into those irritating pre-set angles"
SNAP ON
FF80
Dual 80® Technology Ratchet Features:
80 tooth gear
7 teeth in contact with gear to provide strength and durability
Ratchet Arc - Dual 80® Technology ratchet has 25% less ratcheting arc and requires the least amount of arc to engage the next gear tooth
Sealed Head keeps dirt and other contaminants out of the head mechanism.
Banana Man
Los Angeles
I don't know why you're being a hater, :dunno: I'm just adding to the discussion.
Thanks for the rude and unnecessary comment. It's easy to talk like that online my friend.
Have a good night, pal.
kctyphoon
None of that is directed at you, which is why nothing you wrote is quoted in my post... It's actually a response to a rude comment someone else made.. :wtf:
HomeTheaterMan
If he hasn't already bought it, he may want to reconsider. The SO FF80 as posted above meets all of his requirements except for the price. If you shop around on eBay, you can come very close to that price as well.
AmishFury
my comment was mildly rude yours as i've seen often from you is outright hostile
calm down and don't take the internet so personally
LB-1911
Northwestern Il.
Spend $6 more and get this. The Armstrong Maxx are 88 tooth, all metal, a thinner head than the Snap On, and the locking flex head unlocks so you just have a swivel head. I have all 3 sizes, and they're excellent. IMO better than Snap On.
Pretty sure he went w/a Proto J5257F.
Looks like we have a winner. Thanks.
Proto J5257F.
I agree with ^ but this ratchet has 72 teeth not the 80 you were looking for.
The Proto 5257f is a awesome choice.
Wes J
Peoria, IL
It's a myth that when unlocked those are like a Snap On flex head. The locking device acts like a dentent but it's too weak. The only way to tighten the mechanism is to tighten the screw which sort of works but makes them tight in the middle and floppy at the extremes.
The real non detent flex heads from Snap-on, Wright, Proto, SK, Blackhawk, and others use a small spring that looks like a lock washer to set the drag on the flex mechanism. The screw just holds it together, it does not adjust the drag.
DeliveryGuy
Dartmouth, Nova Scotia
Do you like the wide metal handle over a rubber grip or hard handle?
Yes. I prefer chrome handled ratchets. I can feel the hard handles on my Snap On's twist if I pull hard enough.
Actually, I use shorter ratchets and wrenches more frequently. I do use my Armstrongs a lot, but I have a standard length, non flex, Gray T8532 that I use mostly. I find that if I'm ratcheting with my wrist rather than pulling the handle, normal length ratchets are more comfortable.
The Armstrong Maxx locking flex are definitely my favorite long/flex ratchets, though.
