3/8" Snap-On Impact Swivel Sets - Skips?
The Critic
CA
207IPLFM - 3/8" deep metric impact swivels
207IPSFM - 3/8" semi-deep metric impact swivels
Both sets only include the 10mm, 12-15mm, 17mm and 18mm.
Notably, 11, 16, 19mm are missing.
Does anyone know why SO decided to omit those sizes? I understand the omission of 11mm/16mm, but 19mm seems like an important one to leave out.
Thoughts?
lbhsbz
Long Beach CA
Thoughts?
So they can sell it to you individually for $50
ecotec
So they can sell the set at a certain price point… and then sell you the other ones onesie twosie.
purplezr2
Central MN
I bought a the Matco Pinless ones. Pretty much my only Matco tools. They are full sets with no skips.
Odd-job
Not trying to defend Snap On with their shrinkflation here but 19mm and 3/4 can get beat on with some 3/8 guns with the pressure cranked up. 17mm and above one should consider stepping up to 1/2. Then again there is the almighty Snap On 4ever warranty.
drtyler
In SAE, the set includes up to 5/8” (16mm).
I wonder if this is their way of suggesting to use 1/2” drive for larger sizes?
They are available individually, and I don't think Snap-on typically discounts the tools in sets. You just miss out on the plastic tray.
msbytes
They do make a 21mm 3/8 drive swivel which I own and abuse. So far, so good.
T
The Critic
CA
Valid point(s). I admit that 19mm is probably borderline for a 3/8", but many brake caliper bracket bolts are this size. Some are not on very tight, others can be pretty outrageous due to the threadlocker.
Gotta ask - what applications do you use that for?
msbytes
I initially bought it for loosening strut bolts for camber adjustment during alignments. But also works great on other tight suspension spots. It's a semi deep swivel IPSFM21
KnurledNut
n/a
They did at one time...
Old part numbers:
214IPSFMY: 14 pc. semi-deep 8-19, 22, 24
209IPLFMY: 9 pc. deep 8, 10-19
Sycan
11mm equals 7/16ths
16mm equals 5/8ths
19mm equals 3/4
I guess if you don't have both sets you gotta buy some individuals
Zewnten
Cornwell doesn't skip haha It's so car guys can only buy what they need and then go crazy when they find a none OEM bolt on the car and have to buy another size.
