3/8 to 1/4 reducing extension. Does it exist?
DeliveryGuy
Dartmouth, Nova Scotia
I'm looking for a 3/8" drive extension that reduces to 1/4" drive. Basically, a long 3/8 to 1/4 adapter.
Mac has a 1/2" drive set that reduces to 3/8". I've searched for a while, and can't find such a device.
Does anyone know if they exist?
Thanks.
wmartin
I expect that Apex makes an impact extension like this. I'm fairly certain you wouldn't want to pay what they are asking.
devoncoolman
quakertown pa
the problem wdfith this idea is that 1/4 sockets arn't designed for the torque that a 3/8 ratchet and/or impact will deliver. thats most likely why you can't find one. the tool companys arn't gonna make a tool they know will break sockets all the time which will cause their warrentys to rise.
CWP1616L
USA
They make an extension adapter in 12 inch and 36 inch, but they're 1/2'' drive down to 3/8'' drive. They do exist, but not in the drive sizes you want.
D
DeliveryGuy
Clearance may be an issue. I'm an overhead door service tech, and I work off of ladders and scissor lifts a lot, so having as few tools as possible to get the most work done without running back to the truck is a must.
I suppose the adapter method is best. I need to tighten sprockets with small allen screws (hex bit sockets) and regular nuts and bolts without having a tool belt clogged with tools.
mypov
I actually did this the other day. Was working on a cat c15 engine and removing the intermediate valve cover. There was a ******* of a fastener located under a coolant hose and fuel line at the front of the valve cover. Was definitely not getting in there with 3/8" drive - actually I ended up prying the lines to torque the valve cover on, but removing was made simple by putting a 3/8" to 1/4" reducer on the end of my 3/8" cordless impact. Handled the torque fine, but those bolts are only torqued to 15 lb/ft...
One would not be able to get very torquey with this setup, but would be beneficial for clearance issues as mentioned. But I would go the simple way and simply buy a reducer then you can use the extensions you already likely own...
Wrenches of Death
A red state.
Buy an adaptor & extension (in the length you want) then weld them together.
Or drill and roll pin them. I did that to an Indestro 1/2" drive ratchet. I installed an Apex 1/2" to 3/4" drive adapter. It won't pull off or fall off. That 10 or so long ratchet is handy as hell in the 3/4" drive box.
WoD
SuzukiGS750EZ
In the shop I just use my Bosch ps21 and a t25 bit with a 3" extension :) works wonders on them.
diesel research
gulf coast, TEXAS
$8 off the truck (individual, not kit), 6" length SDMT625
Sterff
PA
I was just think of this today. I need a locking 3/8 to 1/4 extension. This would be great with a 1/4" drive swivel on the end.
