Joah_from_Alberta
- Joined
- Mar 14, 2024
- Messages
- 2
Hiall, our new (2 years old) Mr Heater MHU50 garage heater stopped working. It is blinking 3 times. We tried to remove the white vacuum line going to the blower and use a paper clip (it seems to only go in as far as the ****** then stops against something metallic). Also when I try to put pressure to the valve using my mouth it either only goes in very small then stops or goes out very small then stops (like the valve is not allowing the flow??)
I confess I did not spend much time learning about HVAC but I want to be able to repair this on my own. Any support or help would be appreciated.
