3 phase 220v but has a phase converter .... ???
thinkracing
McKinney, TX
I need some help. I'm looking at a drill press. It is 3 phase 220v but comes with a phase converter.
What is a phase converter and what does this mean for my garage?
I have a few 20 amp outlets. I'm trying to understand what I'll need to make this press work for me.
G_P
Central CT
The phase converter will allow you to run the 3phase machine on single phase power you have at home.
it's 220v so a standard outlet wont power it. You would probably need to run a seperate 220v circuit to it unless you have dryer/oven outlets in your shop.
darkk
Willimantic, Ct.
Phase Converters also cut some of the horse power of the equipment being used. The cheaper types cut the most power...here is a cut and paste from somewhere on the internet.
Below, you will find a list and a brief description of each one. The static and the rotary converters are the most popular ones in the market today.
Static-Phase Converters: These are the first phase converters and have been around the longest. The uses are limited, and if you have a smaller motor or one motor, these may do the job. Remember that static-phase converters do not convert one-phase power to three-phase power, nor do they generate three-phase power. The static-phase converter will not power any type of machinery with three-phase circuitry. Static-phase converters operate by producing a third-phase of power for only a few seconds doing the startup of electrical motors.
Read more about static-phase converters.
Rotary-Phase Converters: A rotary-phase converter is designed to power larger equipment and higher HP motors, and a single unit can provide a continuous reliable source of three-phase power to more than one machine. These converters are a popular choice when you need a continuous source of three-phase power. A rotary-phase converter uses it's own motor to generate the third, high leg of power as well as passing on the other two legs of power provided by your single-phase power source. Not all rotary converters are the same; many companies just convert single-phase power into unbalanced third-phase power. Quality three-phase rated converters use a balanced three-phase generator with power factor correction. Properly installed, a rotary-phase converter should operate 35 years or longer.
T
thinkracing
McKinney, TX
Thanks for the great responses! I've got an electrician available to install a 220v outlet. I bought a nice Clausing 20" drill press that I'm picking up this weekend.
Steve from Socal
Hutchinson Ks.
Before you make a claim like "ALL phase converters cut some horse power" perhaps you should understand what you cut and paste?
A rotary phase converter or a VFD will produce three phase power just like a utility with no electromotive power loss. You will have an additional load for the converter but, that is not a loss in power to a motor. There are a few exceptions to the use of a phase converter in lieu of utility three phase, like regenerative braking on the bus that are out of the scope of this topic.
Trying to be helpful is only good when you can offer meaningful advice, making rash statements without basis is counter productive.
Steve
