Hi all,
I'd like to use a changeover switch to switch the output from a vfd between three identical 3 phase motors. I understand all the warnings about switches or disconnects on the load side of a vfd, but the switch will be in a locked cabinet in a single user environment, so I'd like to proceed.
I bought one of these:
http://www.amazon.com/gp/aw/d/B00GW...e?ref_=pe_385040_30332190_TE_3p_M3T1_ST1_dp_1
Unfortunately, it came without a wiring diagram or any English instructions. The store told me they don't have any English instructions available.
The switch has 12 terminals, but none are indicated as "input". I took a multimeter to the switch in the zero position, and found 3 terminals on one side with no continuity with any of the other terminals. Good so far. But, when I switch to any of the other positions, at least one of those "input" terminals will show continuity with more than one other set of terminals. I'm a bit confused as to why - I understood that switching only 1 or 2 of the three phases is not desirable. Or, is this switch not the correct type for this application?
Thanks in advance for any advice ,
Lee
Lee
